Got my new Rotors and brake pads but...
Old Aug 16, 2009 | 08:39 PM
mmotown's Avatar
Got my new rotors and brake pads from Rotorpros and had them installed this weekened. However it seems like my pads aren't stopping my car as well as my other pads from Just Brakes. When I apply my brake it stops the car but it feels like my rotors are slipping through my pads unless I apply more pressure. There is nothing wrong with my brake sytem either. I hope I am making myself clear.
Old Aug 16, 2009 | 09:26 PM
STILLENGLE's Avatar
Did you take the clear coat off of the rotors from the factory?
Did you break them in properly?
Did you install them properly?
Old Aug 16, 2009 | 09:45 PM
DAVE Sz's Avatar
Hooooooonda.....
clear coat? I think you mean oil.........
omartopsecret's Avatar
who installed your rotor's and your brake pads?
Old Aug 16, 2009 | 09:53 PM
you are going to have to resurface your rotors and your pads i think it's $15 buck for the rotors i dont know for the pad you could go to any brake shop.
Old Aug 16, 2009 | 10:29 PM
DeusExMaxima's Avatar
Before u install them, u have to sand the surface. I do it by hand or u can have brake shop do it. I also scuff the pads. I tihnk i use 100 grit sand paper. Then u have to bed them in after u install them. This means driving at 35 and braking slowly to stop a few times, and then 40 mph and stopping etc.
Old Aug 17, 2009 | 07:36 AM
NIKV69's Avatar
I disagree with the sanding opinions here. When I bought my drilled and slotted rotors I cleaned the oil properly and installed new pads. The performance is awesome. Two years later and no vibration and still good breaking. New rotors only need to be cleaned of the material used to prevent rust before install.
Old Aug 17, 2009 | 10:25 AM
KCMAXX's Avatar
KC's FINEST
Im having problems too. I painted mine though...
Any ideas?
Old Aug 17, 2009 | 10:55 AM
maxed_out_saloon's Avatar
why paint them? when u break the paint will come off the pads and rotors
Old Aug 17, 2009 | 11:44 AM
mmotown's Avatar
Guys thanks for replying. A friend of mine installed them. He's a general mechanic. However he got eact rotor and sprayed them down with some type of solution. That was all and nothing was done to the brake pads. So where do I go from here? Get my rotors resurfaced? Thanks!!!!
Old Aug 17, 2009 | 07:32 PM
LucKie1nE's Avatar
It just needs to get broken in.. The stuff he sprayed on your rotors are called brake cleaner to remove the oil they put on it to prevent it from rust during storage until someone purchases them to be installed..
Old Aug 17, 2009 | 08:24 PM
chernmax's Avatar
Nations 1st 6th Gen Turbo
Any ideas?
I would be pissed if someone painted my grass silver...
Old Aug 17, 2009 | 11:37 PM
STARR's Avatar
When you have new rotors and pads installed the brakes feel horrible, drive it around and step on the brakes, best thing to do is take it on the highway when it's not congested, drive at the normal speed of say 60 and brake to 30, do that like 5 to 10 times, you can slowly increase the speed, that will bed your brakes in and within 500 to 1000 miles your brakes will feel great and should steadily improve
Old Aug 18, 2009 | 08:29 AM
bdmaxima's Avatar
just give ur brake mads a good 400-500 miles and u'll see a good difference
Old Aug 19, 2009 | 07:38 AM
BadBlackMaxSL's Avatar
So, why dont you have to break in the brakes on a new car? I'm asking b/c I am getting new brakes in the next couple of months. I've never had to break in any new brakes I've ever had professionally installed.
Old Aug 19, 2009 | 09:30 AM
http://www.350z-tech.com/zwiki/Brake_Pad_Bedding
Old Aug 19, 2009 | 03:31 PM
chernmax's Avatar
Read the link Deus posted! And I suggest you do it soon before you wind up in someone elses back seat!
Old Aug 20, 2009 | 07:12 PM
LucKie1nE's Avatar
Because as soon as the car gets from the assembly line to the delivery truck to the dealer.. The technicians perform a job task called a P.D.I. Pre-Delivery Inspection.. Which means the technician check fluid levels, electrical, tire pressure, grease, etc.. They also do a road test 5-10 miles at least to check for vibration, pull, alignment, etc.. Also to break in your brakes.. Ask me how I know.. I'm a technician and work at a dealership..
Old Aug 22, 2009 | 12:56 PM
po8pimp's Avatar
try a softer pad if you are concerned with this. If you have ceramics and are in a colder climate area even after you do the brake in steps you will experience this for the first few miles until the brakes are warmed up. Brake pads are probably the cause. check what kind of compound your brake pads are made of and post it. I recommend semi metalic if you don't race or drive hard/brake alot. If you do drive hard or race go with ceramics by rabestos or similar.
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
