Introducing New 6th gen traction Rods!!!
Old Nov 21, 2009 | 11:31 AM
TAZ's Avatar
TAZ
Introducing new Racingline Traction Rods for the 04-08 Nissan Maxima
Traction Rods are used to absorb unwanted deflection in the OEM control arm. Largely do to the OEM's rubber bushings, under hard acceleration the control arms natural motion of up and down can be compromised by the forces created as the axles try to turn the front wheels. This deflection is then translated in to things like wheel hop and under some circumstances, torque steer.
Traction Rods help to ensure the correct suspension geometry under acceleration and stop the "toe-in/toe-out" condition created when the car is under load. This assists in power transmission to the ground and therefore faster acceleration in straight lines and coming out of corners in both wet and dry conditions. Some additional toe adjustment for front alignment may also be obtained.
Easily mounts to the car in less than one hour. Almost no ground clearance is lost during the installation of these Traction Rods. As measured on a vehicle lowered 2", the lowest point of the kit is 1/4" higher than the subframe and directly in line with the wheels center line so there is no risk of scraping the rod on a speed bump.
Perfect for any car that sees track duty, whether it be drag or autoX, the difference in feel and power transmission is felt immediately!
All joints are anodized precision 3 piece hiem joints with teflon liners for long service life.
All hardware and instructions are included
Racignline Performance Traction Rods $ 159.99
Old Nov 21, 2009 | 11:45 AM
Oolatec's Avatar
Nice! Had no idea you were working on these! As I understand it, they aren't for daily use, but for when you are on the track, correct?
Old Nov 21, 2009 | 11:50 AM
TAZ's Avatar
TAZ
I've been quiet but I haven't forgotten about you guys....
It's encouraged for track use only but they can be run on the street without damaging them. My 2 test cars have been daily driving them for the last 2 months (one tester is an on the road salesman so the cars sees lots of miles).
The design does not inhibit or interfere with any suspension travel or operation. Also note the brackets shown in the pic were an early sample.. the ones supplied with the production kit are much stronger and thicker, with better gusseting.
Old Nov 22, 2009 | 10:16 AM
morteljc's Avatar
so... no benefit for street/everyday use?
Old Nov 22, 2009 | 01:53 PM
mist max2000's Avatar
any way to fit this onto a 5th gen ?
Old Nov 22, 2009 | 04:13 PM
Sawbladz's Avatar
That would depend on how you drive on the street. If these essentially eliminate deflection which is probably attributed to the stock rubber bushings, then the benefits would be seen all the time. However, I have never been a proponent for heim joints for street suspension. Those are typically used in race applications and eliminate flex but also transmit vibrations. In race applications the suspension is checked over constantly to inspect for failure. Street cars are usually a set and forget type of deal. They get installed and never checked again.
I would be interested to see the benefits of polyurethane bushings to replace the factory rubber. They have been used with success to eliminate deflection and therefore, wheel hop.
Old Nov 25, 2009 | 07:06 PM
TAZ's Avatar
TAZ
Over the holidays we plan to look into control arm bushing kits and a few other toys
Old Dec 1, 2009 | 03:36 PM
6spBaDAsS6ThGeN's Avatar
very happy to hear about the bushing kits i will be purchaseing both
Old Dec 2, 2009 | 10:10 AM
kamski's Avatar
.org extraordinaire
You!!! Call me. LOL
Or I'll sick your mom after you.
Awesome part though, wish I had this on the Max when I was beating on her at Mosport
Kamski
Old Dec 2, 2009 | 01:11 PM
lobewiper's Avatar
Racingline,
Exactly how much is zero to 60 time reduced by the use of these rods? Or has such a test not yet been conducted? Thanks...
Old Dec 2, 2009 | 01:21 PM
DeusExMaxima's Avatar
I imagine you will drop a tenth or two to 60 mph. I think these will be much more noticeable under aggressive driving.
Old Dec 2, 2009 | 08:27 PM
TAZ's Avatar
TAZ
Originally Posted by lobewiper
Racingline,
Our test car noticed an average 0.2 seconds off his 0-60 times
definitely, but those that keep them on will also see some benefit while street driving as well and in corners.
here's a few guys who posted on the other forums about he parts performance so far, it's a little lat ein the season so alot more track result and reviews will come in the spring I'm sure since most tracks are closing up for the season except in CA, AZ, FL, TX, and a few others
http://www.nissanclub.com/forums/3875636-post39.html
http://www.nissanclub.com/forums/3875584-post38.html
http://www.nissanclub.com/forums/3874731-post32.html
Old Dec 3, 2009 | 04:11 AM
lobewiper's Avatar
How much MORE aggressively can you drive from zero to sixty than you do during a 0-60 run? Am I missing something here?
Old Aug 12, 2011 | 11:07 PM
imjustinlampe's Avatar
so anyway to get these to fit a 5th gen
Old Aug 13, 2011 | 07:40 AM
Kryogen's Avatar
What holidays? xmas?
I suspect my ebay control arm bushings are causing a clunking noise.... so if you guys make bushings and I still havent figured out my issue, I'll but them from you and try em.
Old Aug 13, 2011 | 08:29 AM
lulz's Avatar
why are these recommended only for track use??
Old Aug 13, 2011 | 02:06 PM
NiZMo1o1's Avatar
when your auto-X or drag this helps reduce wheel spin for better launch, I dont suppose you dump 4K RPM in 1st gear during your run to the grocery store ?
street cars / daily cars will benifits as well but this is like advance suspension101
Old Aug 14, 2011 | 07:18 AM
Pinto's Avatar
i ran similar rod on my s14 and granted that car had 500whp but even putting them on more stock dailys give you a better feel for the road. i say its just another step to lowering kit, strut bars, sway bars and links
Old Aug 15, 2011 | 10:15 AM
Are these still for sale?
Old Aug 15, 2011 | 10:33 AM
TAZ's Avatar
TAZ
Yes Mark they are on the Racingline Performance website and have since gone trough 2 revisions making them even stronger and quieter for track and daily street use
Old Aug 15, 2011 | 10:57 AM
Ill check em out there!! I have never liked the wheel hop i get with my car.
Old Aug 15, 2011 | 04:00 PM
lulz's Avatar
i understand that part. what i mean is, why would you not want to run them on the street, are there any cons to street use? I do drag race this car but its also my daily.
Old Aug 15, 2011 | 04:08 PM
taz394's Avatar
without a doubt a great product
work as stated ...
Old Jun 19, 2012 | 07:19 PM
CanadianMoFo's Avatar
Resurrecting a dead thread here...however...
I'm wondering about putting these on my daily driver. Also wondering about how they get adjusted. Am I reducing the length, essentially snugging it up to prevent toe-out? Or am I to expand the length to prevent toe-in?
CM
Max139617
Sep 20, 2015 07:09 PM
hot04
Sep 18, 2015 06:14 AM
240tomax
Sep 13, 2015 03:28 PM
ef9
Sep 10, 2015 10:35 PM
