New Tails....
Old Dec 28, 2009 | 10:35 AM
Veniality's Avatar
New Tails....
Finally installed my new tails. looks really good. everything is fine except when you put your lights the signal lights blink so fast. try to play with it.
nothin.....ideas?????:confused :
thanks greatly appreciated.
i know we have these post already but to no avail i cant find it.
Old Dec 28, 2009 | 11:50 AM
Ryaliu's Avatar
what a clean rear end. You just need to unplug the connections and reconnect them making sure the contact is perfect.
Old Dec 28, 2009 | 01:17 PM
lblackonblackl's Avatar
SHIFT_my stick
yeah it should blink normal. at least mine did anyways. its all plug n play.
Old Dec 28, 2009 | 01:37 PM
ILL-Maxima's Avatar
Lookin good Veniality! So far as to the fast blink i had that also when i first installed mine. Just make sure all the contacts are making good contact with the contacts in the housing. I had to bend my contacts coming out of the leds. haven't had any probs since then...
Old Dec 28, 2009 | 02:00 PM
Gollum67's Avatar
Looks good V!!!
Old Dec 28, 2009 | 02:43 PM
Propa Teknique's Avatar
If a bulb in the LED tails goes out, do you just replace one bulb for all the LED's or do you change a each LED as each one goes out?
Old Dec 28, 2009 | 03:01 PM
blaxima06's Avatar
Do you have switchbacks for your headlights? If so, you need a 3ohm resistor. If not, just play around with the plugs.
Old Dec 28, 2009 | 03:02 PM
blaxima06's Avatar
The only bulb used for the LED taillights are the reverse lights.
Old Dec 28, 2009 | 04:15 PM
SmokinMaxSE's Avatar
SmokinMaxSE
Are your hazards on in those pics. When you step on your brakes the two circles on both should only light. The turn signal will blink fast if the brake lights and turn signal lights are switched around.
Note, your tail lights will look like your brake lights. The difference is the intensity of the light. It will look like your driving with your brake lights on.
Old Dec 28, 2009 | 05:18 PM
DAlastDON's Avatar
Nice looking tails. I have the same ones.
3ohms is incorrect if you have LED bulbs in the front turn signals and the LED tails from ezkoncepts. The ezkoncepts already have a 6 ohm resistor built in them. Thats what makes them plug-n-play with a stock car.
Its 6ohms per LED light. Two 6ohm resistors in parallel=3ohms. If you put a 6ohm and a 3ohm resistor in parallel then you will have 2ohms. It will work at 12v but not at 14.x volts. The BCU will see a higher current draw and will flash the turn signal a few times then it will stop because the BCU thinks there is a short in the turn signal.
I went through this when autolumination.com sent me 3 ohm resistors instead of the 6ohm resistors i ordered. I didn't verify the resistance values before installation and my headache of finding out why the turn signals only worked correctly when the car was not running began.
Old Dec 28, 2009 | 05:43 PM
bigpopaj369's Avatar
they look real good! love those tails on the 6th gens
Old Dec 28, 2009 | 06:15 PM
KCMAXX's Avatar
KC's FINEST
Fog alert...
Looks good.
Old Dec 28, 2009 | 09:10 PM
RAZ76's Avatar
Originally Posted by KCmaxx
Fog alert...
These tails fog up??
Old Dec 28, 2009 | 09:26 PM
blaxima06's Avatar
Your right Don, its 6ohm, my bad, thanks for the correction.
Old Dec 28, 2009 | 09:32 PM
LiquidEliteMax's Avatar
Hey Don, I also just installed the LED Tails and the blinkers are going crazy. What do I need to fix this? These are the only leds I have on my car.
thanks!!!
Old Dec 29, 2009 | 02:25 PM
KCMAXX's Avatar
KC's FINEST
Yep.
PM sent...
Old Dec 30, 2009 | 08:05 PM
I3LAZEN's Avatar
Enjoy the tail lights!! Not all of them fog up ... I kno mine didn't.. +1 on the question abt if 1 led goes out... what happens if any of the leds blow?
Old Dec 30, 2009 | 09:08 PM
DAlastDON's Avatar
thanks!!!
Follow this mans advice.
Old Dec 31, 2009 | 01:18 AM
bryantrachi's Avatar
that looks so sick i got a white maxima too how much did that cost and who installed it??
Old Dec 31, 2009 | 11:47 AM
Veniality's Avatar
ezkoncepts.com plug and play with it.........lol
Happy New Year everbody....... be safe than sorry
Old Jan 1, 2010 | 06:22 PM
elchinophil's Avatar
They are flashing fast before of the connection. I had the same problem with mine. The little pins that come with the taillights do not make full contact. You must prop them outwards and then towards the direction of the connection. I had to use a flat head to bend it out and move them towards a angle to get a connection. It's trial and error. I had the smoke ones and then someone hit me so I replaced them with the RED ones. It looks much better for my silver 05 SL. Anyhow, your not going crazy , we all had the same problem.
Old Jan 1, 2010 | 08:31 PM
Veniality's Avatar
as i said Plug and Play with it.... problem fix. looks good
Old Jan 2, 2010 | 07:05 AM
Lovemycar's Avatar
I've had mine for about a year i've never had any fog
Old Jan 3, 2010 | 06:07 PM
dodonik's Avatar
That looks really awesome!
Old Jan 4, 2010 | 07:03 AM
flyanbrian's Avatar
that looks awesome i might have to get a set!
Old Jan 8, 2010 | 08:17 AM
sweetlou's Avatar
Looks great! I love them.
Old Jan 8, 2010 | 10:24 AM
03MajesticMax's Avatar
Shift_MajesticFemale
This is exactly what happened to me... i was getting 2-3 normal blinks and then a fast blink... I first tried playing with the connections and that did not fix it... turned out that my brake lights and turn signal lights were switched around
Old Jan 9, 2010 | 04:16 PM
Veniality's Avatar
exactly what happened to mine...... switch it around everything is working fine.....
Old Jan 10, 2010 | 04:26 PM
smanonfire's Avatar
i just bought those same tails! can't wait to put them on and smoke them
Old Jan 10, 2010 | 08:31 PM
Hi guys, can someone help me with the blinker fix? I live in Queens NY.
Old Jan 12, 2010 | 06:27 AM
chernmax's Avatar
Nations 1st 6th Gen Turbo
Nice!!!
Greeny
May 30, 2013 04:27 PM
b13ownr2
30
Oct 22, 2012 10:48 AM
AGRECORDS
Sep 20, 2005 04:37 PM
piotroosh
30
Jul 10, 2004 12:31 AM
