Transmission Issues....I think
...it's been a very long while since I posted here and it's very nice to see a few recognizable names still around, with that said this is my issue...
For a while now I've noticed that the way my Maxima drives is getting progressively worse and worse. To start, at times, when I shift from Reverse to Drive, it gives a very loud "bang" or "kick". The same thing occurs at times when the car is shifting up, or when it's down shifting, and those at times are pretty damn bad. They sound as if though I've gone over a pothole or something with the loud banging noise it does and the strong kick you feel. There's also the issue that when it does shift and it doesn't kick or bang, it sounds as if though the gear slipped or something and in some instances I have to ease up from the accelerator because the car doesn't seem to want to shift until I release the accelerator slightly. Finally, as of late I've been feeling like a "sputtering" feeling when driving at times similar to going on a bumpy surface, but only the car is driving on a smooth road. I'm already preparing myself for a new tranny, bu can it be that perhaps it may be other things and not necessarily a tranny issue?
Before you go spending loads of money
http://forums.maxima.org/6th-generat...ssion-fix.html
There is now a fix for these issues.
If you get these parts , I can recommend you ATFspeed.com
to install it, if do decide to go this route , let me know , I will give a heads up to ATF , they are located by 595 in Davie.
would be to buy the shift kit, and then take it to a transmission repair shop to install it.
Or does my Transmission need to be replaced/repaired/rebuilt before i can install the shift kit ?
Urgent please
are you saying if for some reason the transmission needs to be replaced ?
Im a total noob. (im an IT-Tech thats all i know )
Pied
Sep 26, 2015 03:29 PM
