How to replace 2006 Maxima driver side mirror
Old Feb 19, 2010 | 06:50 AM
masama's Avatar
Long story short, I broke my driver side mirror when I backed my car into my garage. I don't want to be ripped off at the dealer, so I found some cheap replacement mirror online for ~ 60 bucks +s&h, but couldn't figure out how to replace it.
Anybody ever replaced a side mirror or remove the door panel on the driver side? Is there any diagram or procedure outline?
Thanks in advance!
Old Feb 19, 2010 | 09:58 AM
MadMax07SL's Avatar
The inside panel's come off really easy. Have you been inside the door to take a look? I can't imagine it's too difficult once you reveal what's going on inside...
Old Feb 19, 2010 | 10:54 AM
KCMAXX's Avatar
KC's FINEST
Theres 3 screws that hold the door panel on.
The first in behind the handle, next pop off the long trim piece thats on the arm rest, theres two more in there.
Pull the entire panel towards you and slide up a little.
Once thats done, the small speaker in the corner has one bolt holding it in place, remove that and unplug the tweeter. Theres 3 bolts that hold the mirror on. Remove those and GENTLY pull the mirror off from the outside.
Pretty simple actually...
I had all mine apart a week or so ago: http://forums.maxima.org/6th-generat...light-mod.html
Old Feb 19, 2010 | 12:08 PM
sensfan1111's Avatar
This should help.
http://ww2.justanswer.com/uploads/ba...es_from_ei.pdf
Old Feb 19, 2010 | 01:23 PM
masama's Avatar
Thanks a lot, guys! The diagram from sensfan1111's link and KCmaxx' descriptions and pictures really help!
BTW, KC, nice mod with the LED on the mirror! That looks really good!
Old Feb 19, 2010 | 01:31 PM
masama's Avatar
KC, is your mirror heated? Did you take the power window panel off, too?
Old Feb 19, 2010 | 01:33 PM
masama's Avatar
I found this one ehow.com....
It goes well with sensfan1111's diagram link...
Unhook the negative (black) battery cable before beginning. The Maxima has several electrical components within the door panel (power windows, locks, mirrors). Unhooking the negative battery cable will prevent shock.
Step
Insert a small flat-head screwdriver or a pry tool between the power window control panel and the armrest. Pop the panel up, and pull it away from the armrest. Unhook the three wiring harnesses from behind it.
Step
Remove the metallic trim cover that runs along the side of the door armrest. Insert a flat-head screwdriver into the corner and pull it away from the armrest. The trim cover is only attached by clips.
Step
Remove the two Phillips screws from behind the metallic trim cover. Keep all the screws you remove in a small cup, so you don't lose them.
Step
Pry off the small screw cover from behind the inside door handle. Remove the Phillips screw behind it. Once this screw is removed, pull the door handle toward you and maneuver the plastic surround panel around the door handle.
Step
Pry off the door courtesy light lens. Once the lens is off, unhook the wiring harness from behind it.
Step
Pull off the fuel/trunk release. This module is attached by clips. Once you pull it off, unhook the harness from behind it.
Step
Start at the lower rear corner of the door panel and begin pulling off the door panel. The door panel is attached by tiny clips all around the perimeter. Once one section comes off, move on to the next section until the door panel is completely detached.
Old Feb 19, 2010 | 01:40 PM
masama's Avatar
I haven't opened it up yet since I am a little worried that I might break something.
Old Feb 27, 2010 | 08:15 PM
ray08max's Avatar
is it true the 09 maxima side mirrors with the turn signal lights will fit and function with no mod on a 08 max
fastcarny
May 18, 2020 10:40 AM
Dennis Twohy
Oct 1, 2015 06:01 PM
Maxilano
Aug 31, 2015 07:33 PM
wpr
Aug 5, 2015 03:28 AM
BassAddictJ
Aug 4, 2015 11:38 AM
