Best transmission fluid...
Old Mar 29, 2010 | 08:44 PM
po8pimp's Avatar
What is the best transmission fluid out there for our car? I have used Royal Purple and also Nissan Matic K. I am currently running around with Nissan Matic K, however I am getting a cooler this week and the shift kit installed very soon and was thinking about going with AMSOIL. One of the performance shops out here told me to stick with Nissan Matic K because they have had their Acura trans fail after adding the AMSOIL to their car. They said that AMSOIL might not have all the minerals needed for our trans. Please post if you have used anything other than Nissan Trans Fluid and how many miles you are going with that fluid.
Old Mar 29, 2010 | 08:47 PM
Oolatec's Avatar
AMSOIL for sure!
Old Mar 29, 2010 | 11:41 PM
NIKV69's Avatar
Best lubricants going. AMSOIL
Old Mar 30, 2010 | 01:28 AM
po8pimp's Avatar
yea I realize they have some of the best out there. Is anyone running it in there car transmission?
Old Mar 30, 2010 | 07:06 AM
Oolatec's Avatar
I did for at least 20,000 miles.
Old Mar 30, 2010 | 04:18 PM
po8pimp's Avatar
did? so you obviously are using something different, can I ask why the change?
Old Mar 30, 2010 | 04:22 PM
thealliance43's Avatar
you guys choose amsoil over oem?
Old Mar 30, 2010 | 04:31 PM
po8pimp's Avatar
that's what this thread is for. I am wondering the same question. I have used Royal Purple before but only for a couple hundred miles. I didn't see a difference and to me it seemed like the tranny would heat up faster causing the problems earlier than when I used OEM. I have done a ton of reading on the Amsoil tranny fluid and it seems to be the best on the market next to a fluid made by Castrol for a specific vehicle. I am one to think if Nissan screwed up on the selection of transmission to begin with then how can I trust them on the type of fluid to go into this transmission to be the best. Seems to me like they are cutting corners and skimping on their products.
Old Mar 30, 2010 | 04:42 PM
niice point... also on the whole thing with them denying the problem really makes me laugh
Old Mar 30, 2010 | 04:45 PM
Oolatec's Avatar
I changed the whole car... lol
Old Mar 30, 2010 | 04:49 PM
po8pimp's Avatar
lol ohh yea totally didn't think before I replied. Your new car is so nice, I envy you and your new car.
Old Mar 30, 2010 | 04:53 PM
Oolatec's Avatar
LOL Oh, it happens!
Yeah check the new thread for pics! Thanks meng!!!
I'm holding off on mods for quite awhile. If anything, just high-flow cats, and maybe an exhaust. Surprisingly, the stock intakes are already pretty damn good.
Old Apr 1, 2010 | 01:12 PM
rohanmax14's Avatar
I'm using mobil one ATF n I changed it every 10,000 miles I'm doing 2nd drain/refill mobil one ATF this weekend hopefully.
Old May 12, 2010 | 12:18 AM
2o4Max's Avatar
How long do you guys let the tranny fluid drain for? It's time for me to drain it before my road trip, I was considering letting it drain for 4 hours? then maybe jack it up at the rear to see if I can get more out.
Old May 12, 2010 | 07:51 AM
aznstormin's Avatar
How often is it supposed to be changed? Every 10k comes up quick for me...
Old May 12, 2010 | 11:14 AM
Oolatec's Avatar
30k.
Old May 14, 2010 | 01:15 PM
rawmax1's Avatar
I just wasted 150 plus on some amsoil for my 2004 maxima 5spd auto. I don't think this is meant for our cars no matter what they say. I sent an email to them. After the first drain and a run to orlando I noticed unsmooth shifts and a strong tranny smell(More dexron like) also no leaks. Put car back on lift drained again did this about four times . Made a run to ft lauderdale car didn't shift as crisp or pull as hard as before. Redrained and put in some Havoline Multi vehicle we have here at the dealership I work at (That i have been using previously for the last 30,000 plus miles and my car is driving and shifting normal again. Sorry for the long drawn out post. But don't blow money like me. I will say i do believe in their motor oil
Old May 14, 2010 | 03:11 PM
stockmaximaFTW's Avatar
NOT INVITED TO MAXUS 2010
it's just oil. use nissan's.
Old May 15, 2010 | 06:45 AM
po8pimp's Avatar
it's just oil? what is that supposed to mean? All oils are created differently and work differently.
I ended up using Nissan's Matic-K for my trans. I was allmost convinced on using Matic-S, which is Infiniti's replacement oil for the Matic-K.
Old May 15, 2010 | 07:03 AM
Kryogen's Avatar
They say k matic only, use k matic only....... tranny is built to run on that oil...
Old May 15, 2010 | 07:09 AM
po8pimp's Avatar
they also say their 5speed transmission was bullet proof.
Old May 15, 2010 | 07:11 AM
po8pimp's Avatar
Exact words from dealership when I went in with my first tranny problem. 2 transmissions and a shift kit later proves they are full of ____ <fill in the blank. Also when I went to Infiniti to get two extra quarts of Matic-K, the sales rep said they don't use Matic-K in any of their cars anymore. Matic-S replaced Matic-K, which used to be used in some of their cars.
Old May 19, 2010 | 06:18 AM
up the middle's Avatar
I used Mobil 1 synthetic.
user 11122324
42
Jul 18, 2022 03:35 PM
Pied
Sep 26, 2015 03:29 PM
