Cleaning filter from my CAI ( FUJITA)
Old Apr 12, 2010 | 11:34 AM
Veniality's Avatar
CAI (fujita)
Is there a special way to take AND clean this out? DO'S and DONT'S
I just dont want any CEL Codes appearing when i put it back....
thanks a lot, really appreciate
Old Apr 12, 2010 | 12:13 PM
the macedonian's Avatar
hey bud - I was going to take out mine last oil change, but was worried like you are so I took it to my mechanic. He said there is no special way to remove the filter and/or clean it.
It took him like 5 mins after the oil change to check on it/clean it out.
Hope this helps man
Old Apr 12, 2010 | 12:23 PM
Veniality's Avatar
Hope this helps man
thanks a lot..... weekend job..
Old Apr 12, 2010 | 01:01 PM
KCMAXX's Avatar
KC's FINEST
Remove the wheel, pull back the wheel liner and pull it off throught the bottom end.
As long as you dont unplug the MAF sensor you wont trip any CEL lights.
If you haven't already, pick up a K&N filter recharge kit, the instructions are on the box.
Or... you could do what I did,
Makes cleaning a breeze...
Old Apr 12, 2010 | 01:20 PM
yeah - I wish I had a garage to be able to do some of the stuff myself .
The downside of living in a condo - next house I get has to have at least a 2 car garage
Old Apr 12, 2010 | 01:52 PM
Nismo4life07's Avatar
Taken from F5air.com
"Cleaning the air filter is simple and can be done using soapy, lukewarm water, and let air dry. The Super Flow High Performance Air Filter™ contains a synthetic fiber that does not contain any oil."
http://f5air.com/filter.html
Old Apr 12, 2010 | 06:59 PM
Veniality's Avatar
thanks for the advice... really appreciate..
Old Apr 12, 2010 | 07:13 PM
no problemo! it helped me too. haha.
Old Apr 13, 2010 | 06:01 AM
Apollos2's Avatar
I bought a 2nd Fujita filter because one of the biggest things you have to watch out for is that the cleaned filter has to be completely dry before you put it back on the car.
You can use a K&N filter cleaning kit and just follow their directions.
1. Remove filter. ( I don't take out MAF or anything)
2. Spray on K&N cleaner, let is soak for a few minutes.
3. Rinse with warm water, not high pressure.
4. Let filter dry completely and reinstall.
With the extra filter, I don't have to have the car down while the filter dries.
Old Apr 14, 2010 | 08:38 PM
Mu33rto's Avatar
Every time I change my oil I clean the MAF and the butterfly in the TB and the filter..If you haven't done that you should...Car will rev a little at first but it should come back to normal. You get a better response from the intake I think. Disconnect the battery 1st if you do that....
Old Apr 14, 2010 | 09:27 PM
RAZ76's Avatar
I've cleaned many filters in my 15 years round this scene and have cleaned many filters. I don't buy that cleaner crap because it's too expensive and no need for it. I always use simple green, let the filter soak in it for about 5 minutes and then rinse with warm water from inside out. Then use a blow dryer for faster dryor let it sit in the sun for about an hour if in no hurry. Never had any issues.
Old Jan 23, 2016 | 05:17 PM
ray817's Avatar
I don't even remove my wheel. Just turn it all the way left and you should have enough room to remove wheel well plastic and the filter is right there to the left of the drivers side wheel. Takes 5 min.
Old Dec 22, 2019 | 02:05 PM
tallblazer124's Avatar
Has anyone purchased a replacement filter. I don't see any fujita filters for sale. Mines is pretty banged up after 10 years.
my03maxima
Jul 28, 2024 07:40 AM
Apr 16, 2020 05:15 AM
Redfox
Sep 28, 2015 10:41 AM
Sep 27, 2015 08:37 AM
