Wheel Spacers?
Old Apr 19, 2010 | 08:22 PM
Jman07's Avatar
Wheel Spacers?
I'm thinking about spacing my wheels on my 2007 max, any suggestions on this little project? As to how wide I should make them?
Old Apr 19, 2010 | 08:27 PM
yevgenievich's Avatar
why putting on the spacers? A wider wheel with the right offset should fit with no spacers and if going to far out it will rub.
Old Apr 19, 2010 | 08:44 PM
lblackonblackl's Avatar
SHIFT_my stick
go either 5 or 10 mm... no more than that.
Old Apr 19, 2010 | 09:43 PM
NismoMax80's Avatar
SuPeRmOd
you go enough to make it worth it and they will rub in the rear.
Old Apr 20, 2010 | 07:10 AM
NmexMAX's Avatar
dot dot dot ...
The A32 & A33 chassis require spacers for an even stance without using a staggered set-up. IIRC, the A34 may be the same. I remember !PRJ also found this out the hard way.
Old Apr 20, 2010 | 08:11 AM
i thought wheels had different offset front to back from the factory. Learn something new every day
Old Apr 20, 2010 | 08:14 AM
NmexMAX's Avatar
dot dot dot ...
i thought wheels had different offset front to back form the factory. Learn something new every day
That’s commonly referred to as staggered. Our cars do not come this way, some cars do.
Old Apr 20, 2010 | 08:32 AM
yea, i always referred to staggered as wheels also having different width, my TA has different offset front to back but same width from factory
Old Apr 20, 2010 | 09:24 AM
the macedonian's Avatar
won't the staggered setup make the ride quality worse - ie shimmy, steering wheel rattle etc etc...
Old Apr 20, 2010 | 09:40 AM
Oolatec's Avatar
Spacers FTL.
Old Apr 20, 2010 | 10:22 AM
NismoMax80's Avatar
SuPeRmOd
my handling seemed as good if not better when i had staggered offsets. but the rubbing on uneven payment, or if anyone sat in the back sucked.
Old Apr 20, 2010 | 10:23 AM
Originally Posted by Oolatec
Spacers FTL.
I use 2" spacers on the front of my TA with no issues. as long as the spacer is retorqued after driving few miles they stay on with no issues. If spacer thin and doesn't have studs then the original studs might not be long enough.
Old Apr 20, 2010 | 12:29 PM
NmexMAX's Avatar
dot dot dot ...
I've been using spacers for a very very long time as well, no problems/complaints.
A quality set of spacers will come with extended lugs. All 3 of my sets did. (5 , 10, 20mm respectively)
Fbana41
Aug 29, 2016 12:18 PM
Andy29
Sep 29, 2015 05:32 AM
Lowered_a33
Sep 10, 2015 09:41 PM
dcam0326
Sep 8, 2015 11:02 PM
Maxboy23
Sep 4, 2015 06:04 PM
