Grounding kits
Old May 14, 2010 | 01:17 PM
SmokinMaxSE's Avatar
SmokinMaxSE
Grounding kits
Recently I installed a Grounding kit. When I grounded the engine, it went from a normal tick to a rapid ticking. Is that good or bad? Someone told me it may have gained a few rpm's. I have no idea and was wondering. It drives the same but I only noticed the normal tick went to a rapid tick. Also, the grounding wires from the engine to the chassis got loose due to vibration. Will it do any harm if the wires are just hanging there? I tighten them again but I'll have to check them all the time.
Old May 14, 2010 | 01:47 PM
importcf's Avatar
use a lock washer
Old May 14, 2010 | 05:32 PM
KCMAXX's Avatar
KC's FINEST
I haven't had any issues with mine.
My overall MPG's increased as well as better throttle response.
Old May 14, 2010 | 06:05 PM
aznstormin's Avatar
Oh man, I still have to make my kit...been too lazy lately, but I have to get the benefits from it
Old May 14, 2010 | 08:11 PM
2o4Max's Avatar
Is that the racing line kit? how long did it take to install?
Old May 15, 2010 | 12:11 AM
Oolatec's Avatar
Eh... grounding kits are a waste of $ IMO.
Old May 15, 2010 | 06:34 AM
po8pimp's Avatar
Probably one of the most important additions for you car. Keeping a completely grounded system is the key to electronics working properly. Think of it like a stereo system. Sure your speakers will work with any ground, but if you use a higher gauged ground you will get better results. Try using a 16 guage ground wire for a subwoofer setup. Crank up the volume, then change to a 4 guage ground wire. You will see a huge difference. Our cars allready come with a grounding system, however certain things are not grounded as good as they could be.
Old May 15, 2010 | 07:17 AM
KCMAXX's Avatar
KC's FINEST
No. I made my own but followed Racinglines online install directions...
http://forums.maxima.org/6th-generat...e-i-bored.html
Originally Posted by SmokinMaxSE
Its all in your head.
Old May 15, 2010 | 07:22 AM
po8pimp's Avatar
That's exactly what I did, but I followed racingline and Stillen's instructions. They are a bit different so I did a combination of the two.
Old Nov 21, 2010 | 08:13 AM
KevMaster's Avatar
Wal-Mart sells battery connector cables. They look exactly like above ground wires kit. They sells for $3.50 a cable with the length from 20" to 51" two to six gauge wires. Just in case anyone is looking for cheap and handy option.
Old Oct 5, 2011 | 06:54 PM
Jliner's Avatar
slightly to long ... and the longer the cable the more unclean the ground actually is :/
Apr 16, 2020 05:15 AM
Pied
Sep 26, 2015 03:29 PM
