Fans and Low bass with AC
So it hit 95 degrees in Chicago recently, and I noticed that with the AC on, and both fans going, there is this very deep bass coming from the front.. and it only happens w/ both fans on...
anyone else?
anyone else?
The fans work extra harder especially when it gets real hot out,they are probably at max speed to keep your motor cool so it wont over heat.And I believe once you turn on the air one of the fans automatically runs and the other one turns on when it needs to for extra cooling. However check the radiator in front of the fans and make sure there are no obstructions there like debris or see if the fins are not damaged which might restrict the air flow which would cause the funky noise. I live in Florida and its hot most of the time so both my fans are on alot especially if you sit in a lot of traffic highway driving they barely run unless if your in the desert.
