Fog Lights
Old Jun 25, 2010 | 07:05 PM
Veniality's Avatar
Fog Lights
Hi Guys,
While driving tonight i notice that both my fog lights are out. this are
suppose to be on when the head lights are on.
pls. if anybody seems to know the problem, can you chime in...
really appreciate..... thanks a lot.
Old Jun 25, 2010 | 07:13 PM
Oolatec's Avatar
They burned out. Replace them.
Old Jun 25, 2010 | 07:20 PM
Veniality's Avatar
the two of them at the same time
Old Jun 25, 2010 | 07:30 PM
tequilateazle's Avatar
you may have shut them off by mistake
Old Jun 25, 2010 | 07:35 PM
Veniality's Avatar
it goes with the headlights....
Old Jun 25, 2010 | 07:40 PM
I VIK I's Avatar
There is a switch next to your headlight stalk that controls the foglights. Check that, then check fuse, then replace bulbs. Troubleshoot in that order.
Old Jun 25, 2010 | 07:45 PM
Veniality's Avatar
thanks a lot, ill try that..
Old Jun 25, 2010 | 07:53 PM
cmejatt's Avatar
check ur fuse and and try to replace bulbs see if they work if not check ur wiring
Old Jun 25, 2010 | 11:20 PM
NismoMax80's Avatar
SuPeRmOd
one might have gone out a while ago and you never noticed.
but like stated, check you have them turned on and so on.
Old Jun 26, 2010 | 06:20 AM
Veniality's Avatar
yeah both light bulbs were out......thanks alot guys for chiming in, really apprecite
Old Jul 9, 2010 | 09:12 AM
Steven Mills's Avatar
fog lamps
I have an 05 Max and i just noticed yesterday that both fog lamps are out and have checked control setting. Cannot determine which is the fuse for them. the dash fuse box does not one one labeled for fog lamps, nor does the box under the hood. want to check fuse before getting into checking a/o removing bulbs. Any one know which fuse and its location? thanks, Steven
Old Jul 9, 2010 | 09:57 AM
DAlastDON's Avatar
Take the cover off in the engine compartment on the passenger side to reveal the IPDM. Open up the IPDM and check 15a fuse#43. If that checks good then check #34 and #41 as well.
Old Aug 6, 2012 | 12:23 PM
harley2005's Avatar
can someone post a fuse number diagram for 2005 maxima ? Where is fuse 43? in the IPDM
Old Aug 13, 2012 | 01:15 PM
deece01's Avatar
hey guys, sorry to bring back an old thread and to sound like a complete newb here. I've done some searches on foglight issues and found that the most common fix is to: a) check the bulbs, or b) replace the fuse. I have yet to check the fuse at this point, but I have found that both my bulbs are not burnt out after i took it to midas.
The midas guy said that it could possibly be an issue with a module i have and to run a diagnostic would start at around 100 bucks. I thought this was crazy talk and not worth it (i dont' live in an area with lots of fog), and left.
I wanted to pick your brains for an opinion as to if anyone else has heard about it possibly being a problem with a module (he never stated what module) or if it is most likely a fuse issue because from what I've read on the site, everyone says its just a bulb or fuse that's out. Any feedback would be appreciated.
Thanks everyone.
Old Aug 14, 2012 | 10:32 AM
FormulaGT's Avatar
Sounds like the Midas Guy wanted to rape you for money. I'd never go back there again.
But if you can find the diagram for the fuse box checkout anything that might be related to the fog lights. Its more than likely the fuse.
Fyi: Fog lights are designed to widen the range of headlights now-a-days. They're more for extending the range that your headlights can't because they're forward.
That and filling the gap in front of your front bumper lol.
The Frye
Sep 2, 2021 11:03 AM
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
