How do i replace 07 headlight cover?
Old Jul 13, 2010 | 03:30 PM
kaseman94's Avatar
i have a pair of 07 headlights. one have a crack in the outside cover. how do i replace them? do they sell them anywhere? also the other headlights projector is loose how do i fix them?
Old Jul 13, 2010 | 03:32 PM
RAZ76's Avatar
You might be able to fix the projector some how but nobody sells just the head light cover. You are screwed on that. You have to buy a different head light.
Old Jul 13, 2010 | 05:37 PM
kaseman94's Avatar
thank you. do you know of a way to fix the projector?
Old Jul 13, 2010 | 05:45 PM
6.5affiliate's Avatar
Well, if your just taking about the lens then I read on some max forum that you could try lightly sand it with maybe 1500 grit wet/dry sandpaper and apply headlight polish with a buffer to finish it off. Might be worth giving it a try....
Old Jul 13, 2010 | 05:56 PM
RAZ76's Avatar
That would work if it was a scratch, but this guy has a crack. You can't sand and buff a crack.
Old Jul 13, 2010 | 05:57 PM
RAZ76's Avatar
What's wrong with it, any pics?
Old Jul 13, 2010 | 08:26 PM
kaseman94's Avatar
it looks normal but when your on a un even road or go on a bump the projector shakes alot.
Old Jul 13, 2010 | 10:05 PM
denbigh97's Avatar
If your headlight assemblies are OEM halogen, you could just open the back cover and tighten the screws inside that holds the halogen projector in place. If you have OEM HID assemblies, then you would have to bake the assemblies. That's the only way to access HID projectors.
Old Jul 14, 2010 | 08:57 AM
kaseman94's Avatar
so i wouldnt have to bake it? and i caould tighten it?
Old Jul 14, 2010 | 11:24 PM
You only reason to bake it, is if you wanna open it and paint it but for anything else, it's a....hell no. Just tighten it man, forget the whole bake your headlight thing, don't know where you got that from?
Old Jul 15, 2010 | 12:24 AM
RAZ76's Avatar
No need to bake to tighten the projector but you do have to remove the bumper to get the headlights out.
Old Jul 18, 2010 | 01:07 PM
kaseman94's Avatar
thats no problem so how exactly do i tighten it? is there a write up?
Old Jul 18, 2010 | 10:51 PM
Once you get your bumper off and the headlight out. All you have to do is open up the area where the headlight housing is and twist it open. If you look into the housing, you'll see about 4 screws that are holding it in place. Tighten it up and..........BAM, your done.
Old Jul 18, 2010 | 11:01 PM
03VIPMAX's Avatar
its probably ur whole headlight thats shakes doubt its just projector try putting ur fingers at bottom of headlight and trying to lift it to see if it wiggles the bottom braket that holds bottm is probably brong and u cant fix unless u get new headlight i have the same problem
Old Jul 20, 2010 | 03:28 AM
kaseman94's Avatar
thanks i will try
vingodine
45
May 21, 2016 12:46 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
KristyKarina
Aug 23, 2015 09:53 AM
maxipower
Aug 21, 2015 11:10 AM
Nintensity
Aug 13, 2015 05:41 PM
