Possible Starter Issue
Old Sep 18, 2010 | 05:28 AM
filipinowise09's Avatar
good morning maxima fam, My car is starts slower than normal, I think it may be the starter is dying. where is the starter located? 2005 Maxima 89,000 miles
Old Sep 18, 2010 | 06:32 AM
Terrentius's Avatar
Battery. Starters either work or they don't.
Old Sep 18, 2010 | 07:34 AM
battery tested good
Old Sep 18, 2010 | 08:19 AM
Machinist's Avatar
Did you remove the cables and check for corrosion?
Old Sep 18, 2010 | 11:25 AM
there is a little corrosion, I'll clean them and test starting it shortly. BTW thanks for the help and suggestion guys.
Old Sep 18, 2010 | 01:11 PM
acercomp71's Avatar
not true- starter can get lazy overtime not giving up completely and giving you low battery symptoms, I had one of those on 97 maxima.
Old Sep 18, 2010 | 01:25 PM
I concur I raised my brow too when I read it, do u know where starter is located on 05 Max, I think I found it but just wanna verify with forum. it look like it may have a protective shield on it, under front of engine
Old Sep 18, 2010 | 02:01 PM
acercomp71's Avatar
sorry, not sure where starter is located on 6th gen, since I just got 2004 recently myself. I owned a 97 for many years though and it was a very straighforward job. Just looked at 2004 FSM (yours is same gen) and yes, it does say for 5 speed auto trans model starter has some shield over it. Just look for it, starter should be sticking out somewhere in contact with flywheel, turning it eventually. I beleive its held in place by two bolts and that's it, well, plus connector. Good luck!
Old Sep 19, 2010 | 07:53 AM
Apollos2's Avatar
I'v noticed my car doing the same thing, it will start but it doesn't fire up like it used to just a month ago. Dealer said my battery failed the test, weird because everything else electrical works fine. I gotta check it further and will probably replace it but not at the dealer for $150.
Old Sep 19, 2010 | 08:00 PM
IIvIIoNsTeR MaX's Avatar
My Max had this early on. After several battery tests (all were good/pass btw), cleaning corrosion and messing with the alternator i decided to grab a new battery.
Worked perfectly. Been like this for about 1.5-2 years now.
Old Sep 20, 2010 | 09:37 AM
dpeles1's Avatar
Yeah could be the starter or battery. Ended up being the starter on my step son's 98 Max. It would turn over slow and eventually just wouldn't turn over.
Old Sep 20, 2010 | 12:32 PM
MaxFan's Avatar
Battery
My 2004SE with 90Kmiles is currently on the 4th battery. Everytime the car starts slowly (or taking several tries to start) I just replaced the battery and it has solved the problem.
My last defective battery (96mo. warranty) was dying after 40mo. I got it prorated to a new one (I am sure to keep the receipt handy for battery).
I was sick of the posts badly corroded. So I gave it a good cleaning. Afterward, my car has been running so much better: throtte response is so smooth, even the trans seems to upshift less-harshly and the abrupt downshifts (at slow speeds) have been absent.
Old Sep 20, 2010 | 12:55 PM
dpeles1's Avatar
With all the electronics on cars now, I have always felt it is worth it to buy a quality battery. (IE Optima) My yellow top Optima lasted over 5 years on my 95 Maxima. One of the first things I did on my 06 Max.
Old Sep 20, 2010 | 04:31 PM
whose125's Avatar
hi maxima fan
i have problem with opened the junk. yesterday i used it's okay, but today it's not open àfter i put the button on the door. my car 04 maxima. who know about that please help me! pm at tranvehy87@yahoo.com
Old Sep 21, 2010 | 10:24 AM
the f*ck...?
Old Sep 21, 2010 | 11:56 AM
Terrentius's Avatar
Originally Posted by IIvIIoNsTeR MaX
the f*ck...?
Done gone and hijacked another thread to ask a question....
Old Sep 21, 2010 | 12:38 PM
That + illiteracy.
Old Sep 21, 2010 | 12:57 PM
Terrentius's Avatar
That + illiteracy.
So true! Kind of sad in this day and age.
Old Sep 21, 2010 | 04:26 PM
lol you guys are a trip, I will try buying a new battery. Does anyone know where the exact starter is located?
Old Sep 21, 2010 | 06:09 PM
Sentinal's Avatar
I think its also the battery. I had the same issue just recently and I thought it might have been the starter since I had bought a battery exactly 1yr before. Turns out it was the battery. These standard batteries from auto parts stores are not good. Next time I have to get a battery its going to be either a Die Hard or Optima.
Old Sep 21, 2010 | 07:39 PM
Terrentius's Avatar
Put the front of your car up on blocks or stands, remove the engine splash-guard, and it will be right in front of you on the driver's side of the engine bay with the flywheel. Belts and pulleys are on the left side (passenger side) of the engine bay, with the alternator being in front just below/down from the oil filler cap and dipstick.
Old Sep 23, 2010 | 06:48 PM
THANKS A MILLIE
Old Sep 23, 2010 | 07:50 PM
6.5affiliate's Avatar
Good luck on getting your car fixed..........which battery are you going for. I heard good things about Duralast and Yellow Top...........
Old Oct 22, 2010 | 02:42 AM
04maxman's Avatar
Starter
Hey guys,
Ive been browsing the forums for a while now and you guys have been a big help with some minor fixes.
I recently bought a 04 maxima used from a local dealer. 101k miles on it. Runs well mechanicaly, but every once in a while(not a regular basis, 2 times in 3 weeks) I go to start it and it just does not start. No click, no slow start(dosent fire at all). All of the cluster lights/radio, and normal lights come on, so im assuming there is pletny of power to it.
I have to crank the steering wheel all the way to one side or the other and then it starts right up. Is this a common issue with 6th gen?
Any help is appreciated guys.
Old Oct 22, 2010 | 03:46 AM
@maxman I changed my battery and it fixed my problem.
Old Dec 17, 2010 | 11:15 AM
Sleepinss's Avatar
Where exactly is the starter located at on the 04 maxima. I tried to search but nothing popped up. It's the 3.5Se
mikeg75
Nov 30, 2015 05:12 PM
Excalibur23
Oct 13, 2015 04:33 PM
rnb754
Sep 14, 2015 11:39 PM
jwright36
Sep 8, 2015 11:45 AM
