headlight issue
Old Oct 10, 2010 | 04:55 PM
mrkhone's Avatar
headlight issue
recently i changed the bulbs. i have the stock hids. the right side keeps on turning off. it'll work sometimes. left side is fine. i rechecked the plugs to make sure they're tight and everything seems fine. before i even put the bumper back on i checked to see if it works and it does. driving later on, it doesn't work. wtf.
Old Oct 10, 2010 | 06:49 PM
Terrentius's Avatar
Okay...well, if I were you, I would start by dropping the bumper and switching stuff (bulbs/ballast) around to see I can narrow down the issue. If the problem follows to the left side, then you will know it is a bulb/ballast issue rather than a wire issue. Then I would switch either bulb or ballast with the right side to narrow it down again. Obviously, this is gonna take some time but at least it is your labor and not some mechanics that you are paying for.
My line of thinking is that road-vibration is affecting either bulb or ballast causing intermittent operation. So, i would narrow it down and replace the part....
Old Oct 11, 2010 | 01:09 AM
mrkhone's Avatar
Yeah I'm gonna try that this weekend. Really annoying. First nite I had the new bulbs in, it was fine. Couple if notes later it happens.
Old Oct 11, 2010 | 01:49 AM
hero782's Avatar
Sounds like the ballast is giving out to me
Old Nov 4, 2010 | 04:58 PM
mattmay94's Avatar
i need help with replacing fog light
Old Nov 4, 2010 | 05:18 PM
mrkhone's Avatar
pretty easy. look in the diy section. drop the bumper then u have access to the headlights. remove the headlights. or if u have small hands u can do it on the car.
MaxLife17
Jun 27, 2019 01:37 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
Vistance
Sep 17, 2015 05:17 AM
mpbclutch33
Sep 8, 2015 06:21 PM
MaxLife17
Sep 8, 2015 02:36 PM
