difference between 04/05 vq35
Old Oct 13, 2010 | 08:46 AM
appleman's Avatar
does anyone know why I am being told an 05 maxima engine won't fit in an 04? the 04 has a 4 speed auto and the 05 has a 5 speed auto. I was told it could be an upper oil pan difference? or perhaps a cam or crank sensor?
Old Oct 13, 2010 | 11:33 AM
NismoMax80's Avatar
SuPeRmOd
If you have one of the early 04 SL that came with a 4 speed auto, it may require more work, but i would think they are compatible. All SE 04 are 5AT unless 6 speed manual. And most SL 04 are 5AT unless an early model with a 4 speed.
Many are swapping vq35's in 5th and 4th gens.
Old Oct 13, 2010 | 12:57 PM
the macedonian's Avatar
well put bud -> +1 on that ^
Old Oct 13, 2010 | 04:53 PM
NiZMo1o1's Avatar
whoever told you that is a dodo head,
VQ35DEs 2002-2008
from 2002-2003 the only difference was they didnt have a EGR on the upper manifold
from 2004-2006 4AT / 5AT / 6SPD , doesnt matter cause the tranny bolts up the same , no change in casting.
from 2007-2008 only difference was the VIAS is made out of plastic.
VQs are the same
Old Oct 13, 2010 | 05:00 PM
Stormzusmc's Avatar
ive got a 05 altima VQ35 in my 02 maxima...a couple things had to be changed but it works
Old Oct 13, 2010 | 07:39 PM
NismoMax80's Avatar
SuPeRmOd
any info on who told you this? I was under the same impression that all VQ35's were the same (except the EGR on 04-06) but many here know more about matching up with different trans and the computers involved.
Old Oct 13, 2010 | 09:41 PM
NiZMo1o1's Avatar
Well the casting are always the same , 4AT / 5AT / 6SPD / 5SPD
Ive done from a 5AT to 6SPD swap in a A34
My buddy has a A32 with a 5spd to VQ35DE
The difference is the TCM for the 4AT/5AT which has nothing to do with the engine itself. just used differnt axles from 4AT/5AT/ 5SPD / 6SPD
if your looking for a replacement motors, again you can get a murano/altima/maxima
that all are FWD motors.
you cant use the RWD due to the timming chain covers and the casting for the motor mounts.
again 2002-2003 no egr
2004-2008 egr
Old Oct 14, 2010 | 09:23 PM
NisTech's Avatar
i am planning to put 06 vq35 into an 03. I know i have to swap out intake manifolds due to egr. My understanding is that the crank pos sensor is in a different location so some are saying to use the same harness but since 06 has egr it will have vsvs as well right? and other stuff. I am planning to use the same ecm that i have already. SO the only feasible thing is to extend the wires for the crank position sensor or modify them. Is that the best way???
mclasser
22
Nov 12, 2020 01:58 PM
mkaresh
Mar 12, 2018 06:48 PM
doctorpullit
Dec 12, 2015 09:39 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
