Transmission class action lawsuit
Old Oct 22, 2010 | 12:22 AM
  #41
Nightscape's Avatar
Originally Posted by nitojr1
Hey guys I'm new here but I've been having the same transmission problems with my 04 maxima and even had the transmission rebuilt once before already but just found out that Nissan has extended their warranty on our cvt transmission here I got this from their web sit nissanassist.com to be exact
Nissan has extended the Nissan New Vehicle Limited Warranty for the Continuously Variable Transmission (CVT) to 10 years/120,000 miles (whichever occurs first) for CVT transmission repairs, replacement, and related towing on all 2003-2010 model year Nissan vehicles equipped with the CVT. The remainder of the powertrain warranty coverage for components other than the CVT transmission remains unchanged. All other warranty terms, limitations and conditions otherwise apply.
Please note that this is not a safety recall, and there are no safety issues relating to your Continuously Variable Transmission.
Hope it helps
Sorry buddy, but your 04 is not a CVT. The issue we're dealing with has to do with the 4spd/5spd auto transmissions in the 04-06 year Maximas. Maximas started using CVT from '07 and on.
Old Oct 22, 2010 | 07:47 AM
  #42
BadBlackMaxSL's Avatar
Originally Posted by 1hawaii50
It's all good if the reason is simply to get Nissan to fix the transmission. If anybody is hoping for a nice payout, you'll be really disappointed.
A fix or extended warranty to the 10/100,000 would be excellent. Acura did it with their TL trans issues- I had a 2002 TL. They even installed a trans cooler free as part of their program and a free TSX loaner for the day. Look at Toyota who is always doing recalls now to fix their issues as well as many other auto makers, Benz, GM, Ford. Nissan doesn't do squat with any of their issues- they did do the rear subframe recall but nothing with the trans nor the shimmy nor rattling front suspension.
Old Oct 22, 2010 | 07:42 PM
  #43
rohanmax14's Avatar
I hope Nissan do n put trans go kit with recall so after that we may never have problem.
Old Oct 23, 2010 | 05:06 AM
  #44
Lovemycar's Avatar
2004-2006 Maxima doesn't have the CVT transmission so that doesn't apply to most of the guys here in the 6th gen
Old Oct 23, 2010 | 06:37 AM
  #45
Rose City Max's Avatar
I would be happy if they would swap it for a 6 speed!
Old Oct 23, 2010 | 08:57 AM
  #46
lionshott's Avatar
I have an 04' with almost 93,000 miles. (5 speed). I have not experienced any problems, however I have recently noticed on very rare occasions the engine will rev up for a second or two while driving approx 35mph, of course the tachometer jumps up for a second, then everything returns to normal. Is this the first sign of the dreaded transmission problem?
Thank you
Old Oct 25, 2010 | 08:17 PM
  #47
SuperMario's Avatar
Thank you
I hate to say it, but it sounds like the 2-3 gear issue, this may be the beginning of the problem. Watch for the really dreaded R to D which may happen soon or take a little while. The car almost jumps when you do this, way nasty. At that point you pretty much have the issue.
Old Oct 25, 2010 | 08:39 PM
  #48
lionshott's Avatar
Thanks for the BAD NEWS! Since I am unfamiliar with this problem, could you explain the R to D problem? Is that the kiss of death for the transmission?
Old Oct 26, 2010 | 07:56 AM
  #49
BossMaxima's Avatar
I have the R to D jump but i was told it could be a cause of motor mounts. Within the next two weeks I will be replacing the motor mounts because two of them are broken and we shall see what happens
Old Oct 26, 2010 | 11:29 AM
  #50
chernmax's Avatar
Nations 1st 6th Gen Turbo
Update: I contacted the law firm for any updates and ws told by the lead attorney they are doing the research and some data gathering and should have an offical word in about a week. Understandable since the goal would be to hit Nissan with hard facts and numbers based on info I already provided including links to all these transmission problem threads so tell you friends if they have issues, post it to mark the time and date and get it on record!
Old Oct 26, 2010 | 12:38 PM
  #51
C MAX's Avatar
i havent had tranny issues but i had everything else. cats went after just 1,000 miles and then recently again, and also powers steering high pressure hose, ac compressor and the car only has 30,000 miles on it.
Old Oct 26, 2010 | 12:53 PM
  #52
chernmax's Avatar
This lawsuit is for the Tranny only due to the high cost to fix or replace!
Old Oct 26, 2010 | 03:40 PM
  #53
firewall's Avatar
I am starting to have the problems dammit! Car shifts very hard between 1st and 2nd, sometimes between 2nd and 3rd, tranny slips between a few gears, got stuck in 5th the other day, and now going from R to D is hitting hard, started today!!!
Just to make sure I get this right, the Transgo kit (http://www.transgo.com/SK-AW55.pdf) should fix these problems, right?
Oh and for the record, I have 110 000 km on the car (roughly 65 000 miles)
Old Oct 26, 2010 | 03:42 PM
  #54
rohanmax14's Avatar
My started after 60,000 miles in 2008 or 2009 can't remeber nothing. Mine is 2004 5spd auto.
Old Oct 26, 2010 | 09:08 PM
  #55
matek07x's Avatar
It does no? The problem is with auto trans ? if I am correct ,or is it with the cvt? why else would it be posted for 6th gens.
Old Oct 27, 2010 | 07:40 AM
  #56
chernmax's Avatar
The 04-06 have a 5spd Automatic or 6spd Manual Transmission. ALL 07-08 have automatic CVT transmissions.
Old Oct 27, 2010 | 12:32 PM
  #57
chernmax's Avatar
Bump!!! This should be stickied
Old Oct 27, 2010 | 02:43 PM
  #58
matek07x's Avatar
so the problem is with 04-06 maximas having auto trans ? or with cvts?
Old Oct 27, 2010 | 03:09 PM
  #59
chernmax's Avatar
Yes this is for NON CVT (04-06 Only)
Old Oct 27, 2010 | 05:05 PM
  #60
Dude, you are typing in English but I get the impression that English is not your first language. This potential class-action lawsuit is for the Maxima years 2004, 2005 and 2006. The Maximas from 2007 on are CVTs and are under warranty for 10 years or 100,000 miles.
Old Oct 27, 2010 | 06:00 PM
  #61
matek07x's Avatar
alright thanks, I was confused thats all.
Old Oct 27, 2010 | 11:29 PM
  #62
DjPrego's Avatar
Hey all. I also started having this issue recently. 05 max A/T, took it to a transmission shop and had 'em take a look. They came back with a complete tranny replacement to resolve the issue. Should I post the Diagnostic and Code they came back with? I'm wondering if I should also hold off on getting this fixed until there's a break in the case or not...
Old Oct 28, 2010 | 05:30 AM
  #63
chernmax's Avatar
More info is better!
Old Oct 28, 2010 | 08:15 AM
  #64
xorbitman's Avatar
Guys I hope this issue makes it to Canada...I used to have a 2002 Maxima GLE which got totaled in an DUI accident involving an 80 year old man coming back from a Xmas party....I digress...the insurance paid for a new car...a 2004 SL Auto which was a total lemon and needed a new transmission after only 9,000 miles! Nissan and my dealer bought back the car from me 6 years ago almost to the day October 2004 and gave me a 2005 SE auto...after 96,000 kms or aprox 60K miles my transmission died back in May 2008 and finally was replaced for free. I have 55K kms or 35K miles on it at the moment and already I started to notice rough shifts in the cold AM up here in Montreal...so I called the dealer and had them change the transmission fluid this week this set me back over $100 (Can/US almost at par BTW). I guess I should to the transmission fix since my extended warranty which I purchased to 100K miles is ending Friday....
Good luck everyone on this an I will be checking this post from time to time...I really do believe that Nissan should do the transmission fix for free and extend the transmission warranty on our cars for 10 year.
Old Oct 28, 2010 | 02:28 PM
  #65
rohanmax14's Avatar
Hey chris can u tell them look into bottom site there r already alot of complaint bout tranny.
http://www.consumeraffairs.com/autom...#ixzz131bGLWEq
Old Oct 28, 2010 | 02:44 PM
  #66
chernmax's Avatar
Thanks forwarded...
Old Oct 28, 2010 | 07:44 PM
  #67
NismoMax80's Avatar
SuPeRmOd
there is no "break in the case"... there is no case. people are simply discussing an increasing problem and hoping for a solution.
IF a case is created... it will take a good deal of time to get started... and a lot more time to even get going before anything "breaks"
Old Nov 1, 2010 | 10:01 AM
  #68
chernmax's Avatar
Received this reply today from the law firm!
Chris, We had a good call this morning with another firm with whom we frequently collaborate. We think it looks promising and are going to consult with a transmission expert this week. Just want to keep you in the loop.
Cory
Cory Fein
Caddell & Chapman
1331 Lamar, Suite 1070
Houston, TX 77010-3027
Old Nov 1, 2010 | 02:18 PM
  #69
saraara's Avatar
Seems like someone is seeing some good bread and butter.
Old Nov 1, 2010 | 03:11 PM
  #70
NYCMAXIMA's Avatar
That sounds very promissing chern, hopefully we can eventually force a recal or a warranty extention. It would be nice to have nissan service my tranny since it seems that the 06 valve body does not have this issue.
Old Nov 1, 2010 | 05:01 PM
  #71
NismoMax80's Avatar
SuPeRmOd
Cory
Cory Fein
Caddell & Chapman
interesting.
only if (that is a result is hopefully obtained) you could get nissan to do the shift kit. i'm thinking although an extended warranty is great... it will just replace it with the same tranny. so a new tranny every xx,xxx miles?
and what about those that baby our cars and it goes just after the extended warranty? doing fine at 71,000 miles. just like the CVT it will likely extend to 100,000 miles. i would be the one to have issues at 100,001 miles
Old Nov 1, 2010 | 09:19 PM
  #72
SuperMario's Avatar
Cory
Cory Fein
Caddell & Chapman
Wow great, good news, we know it should happen. Nissan here we go, you should have done this on your own, but now will be bleeding money for your failure!
On the same topic, I had my Maxima at the shop for 2 weeks for tranny rebuilt, drove the car for one week and still pretty much the same, just very slight improvement, but now I seem to also have a 3-4 jerk... unbelievable.
My Maxima is going back on Wednesday to the tranny shop, THANKS NISSAN!!! Hopefully for not too long, so tired of this issue
Old Nov 1, 2010 | 10:01 PM
  #73
LowVybez2DeMax's Avatar
Damn wish this was for 02-03 autos also. About to go threw my second tranny rebuild one at 45k and another at 63k smh 18k apart
Old Nov 2, 2010 | 12:58 PM
  #74
rohanmax14's Avatar
If they decide to do recall on 04-06 tranny. Then I hope they cover people who past 100,000 miles? I'm at 103,000.
Old Nov 2, 2010 | 07:55 PM
  #75
KevMaster's Avatar
Just curious, will nissan makes aisin seiki to clean this mess? If yes then here comes volvo, saab, and saturn..
Old Nov 2, 2010 | 08:02 PM
  #76
SuperMario's Avatar
LowVybez2DeMax, I suggest you go to 5th Gen threads and start a post just like this one. This thread started just to test the waters and look what happened!
Old Nov 3, 2010 | 09:18 AM
  #77
chernmax's Avatar
Yeah, I essentially got tired of just biatching about it!
Old Nov 3, 2010 | 10:24 AM
  #78
BossMaxima's Avatar
haha im glad this is going through but i wonder what they would say about 130k...
Old Nov 3, 2010 | 10:54 AM
  #79
chernmax's Avatar
I think the bottom line is if there is a flaw with the design of the transmission, it needs to be fixed in all Maxima's with the same transmissions regardless of mileage!
Old Nov 3, 2010 | 07:25 PM
  #80
Lovemycar's Avatar
Thats's really good news nissan needs to be accountable
