E-Brake too soft
Old Nov 1, 2010 | 10:56 PM
eK9aT10pSi's Avatar
E-Brake too soft
Hey guys, the issue im having is that i have to pull up the ebrake handle real high for the car to stop rolling back, even then when its pulled up, it rolls back a bit the stops. ive tightened the 10mm nut a couple of times but it seems i have to pull it up too much than needed.
Old Nov 3, 2010 | 01:21 PM
Shoey1's Avatar
put the nut back to where it was originally and take it to you mechanic and have them adjust the parking brake shoes inside the center of the rotor. that will fix the problem. should be able to stop make the car stop rolling back with about 4 clicks of the E brake
Old Nov 4, 2010 | 04:50 PM
mattmay94's Avatar
I have the same problem in a way. I do have to pull it high and also when i powerslide around curves it doesnt catch on as tight as i would like
TKHanson
Nov 24, 2018 01:39 AM
Lowered_a33
Aug 24, 2015 04:35 AM
twotonezed
Aug 16, 2015 08:10 PM
Wolvee
Aug 11, 2015 12:24 PM
Max2000
Nov 24, 2000 05:56 AM
