Can i please get some help with replacing floor and glove compartent light (led)
Old Nov 16, 2010 | 01:46 PM
bryantrachi's Avatar
I want to change my floor lights on my passenger and driver side (footwells) to red instead of the pretty much yellow light. What do i need to take apart? I found the bulb and know that it is a 194 wedge but i cant remove it by simply pullin it out so how do i remove it?
Also, if i want to change the glove compartment box bulb do i have to remove the whole glove compartment? And how simple is it?
Any feedback is appreciated thanks in advance!!!
Old Nov 16, 2010 | 02:40 PM
DAlastDON's Avatar
They are a ***** to pull out. I put on a pair of latex gloves to get a better grip on the bulb.
Old Nov 16, 2010 | 03:45 PM
Nismo4life07's Avatar
exactly!!! get a pair of latex gloves and wiggle it out.
Old Nov 16, 2010 | 05:03 PM
KCMAXX's Avatar
KC's FINEST
Carefully using needle nose pliers does the trick in the footwell, or reach up from the backside and unlock the socket. Thats what I did.
There are a few screws on the top edge of the glove box, remove them. You should have room the get tto the bulb.
Old Nov 16, 2010 | 08:45 PM
morteljc's Avatar
i used the latex glove trick... but its a pain to put the bulb in... and its kinda frustrating if it doesnt light up and you have to put it the other way around....
Old Nov 16, 2010 | 10:20 PM
For sure thanks !!!
Ok so we dont have to do any removal or unscrewing? You jus pull? And to put the new one in you jus push in it?
Old Nov 17, 2010 | 06:00 AM
BossMaxima's Avatar
Yea just pull in/push out. I had the same problem when I did my led conversion and the biggest issue is to not break the bulb. For the glove compartment I had to unscrew the few screws and then get at it, for under the dash I had to have someone with small hands pull it out for me.
Old Nov 17, 2010 | 08:05 PM
AlexShields25's Avatar
real helpful. im having the same issue, so thanks everyone who left feedback.
Old Nov 19, 2010 | 10:57 AM
BOOTZ's Avatar
I dropped the glovebox and used a needle nose with electrical tape wrapped around it. Worked like a charm!
Old Nov 19, 2010 | 08:00 PM
jsmithsole's Avatar
*moderator*
Yeah the passenger side is weird because the bulb aims sideways instead of straight down, gloves work or going in from behind as KC said...
And buy some red 9 led's from me, bright as...well you know) Link in my sig...
Old Nov 19, 2010 | 08:06 PM
I VIK I's Avatar
Thats what she said
vingodine
45
May 21, 2016 12:46 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
spidgeon
Aug 18, 2015 05:46 AM
220k+ A32
Aug 17, 2015 03:57 PM
silver_i35
Aug 3, 2015 11:23 PM
