Coolant fans
Old Nov 24, 2010 | 09:03 PM
cspangg's Avatar
Coolant fans
Radiator fans doesn't come on and temp gauge goes up when sitting still. Relay checks good! Any suggestions
Old Nov 25, 2010 | 02:43 PM
Terrentius's Avatar
Seems like your thermostat is good. Maybe the problem then is with the fan. These are the options that are given if your temp rises and pertains to the fan
-Harness or connectors (The cooling fan circuit is open or shorted.)
-IPDM E/R (Cooling fan relay)
-Cooling fan
From the service manual:
3. CHECK COOLING FAN OPERATION
Without CONSULT-II
1. Perform IPDM E/R auto active test and check cooling fan motors operation, refer to PG-22, "Auto Active
Test" .
2. Make sure that cooling fans-1 and -2 operate at each speed (Low/Middle/High).
OK or NG
NG >> Check cooling fan control circuit. (Go to EC-506, "PROCEDURE A" .)
Old Nov 27, 2010 | 08:34 PM
rond310's Avatar
no heat
sorry for posting here but I don't have enough posts to start a new thread. I changed my coolant this evening but now I have no heat. I am currently letting the car idle on the ramps with the radiator cap off. I read on other threads that this is how you get the air out. ANyone else have any suggestions.
Thanks,
Ron
Old Nov 28, 2010 | 12:46 AM
DAlastDON's Avatar
Thanks,
Ron
This spill-free funnel makes burping the cooling system go so much faster. When you rev the engine with the radiator cap it splashes coolant out and lets a lil bit of air back in the system. The funnel allows you to rev the engine at a higher rpm with no splash to get the air bubbles out of the heater core.
http://cgi.ebay.com/ebaymotors/Lisle...Q5fAccessories
Old Jan 20, 2011 | 02:18 PM
maj718's Avatar
Also have fan issue
I'm having sort of the same problem. My fans won't run, except when I turn on the ac they run at low speed. If I disconnect the temp sensor plug the fans run at high speed but I loose my temp gauge and my check engine light comes on. Any ideas? Thanks
Old Jan 21, 2011 | 03:18 PM
maj718's Avatar
Replace sensor, same problem.
I replaced the coolant temp. sensor, same issue. I've been driving with my ac on so the fans at least run at low speed. Any suggestions?
Old Jan 25, 2011 | 04:44 PM
cspangg's Avatar
mine don't run at all now!
Old Jan 30, 2011 | 06:18 PM
blakedanatural's Avatar
hello all,
I need help on draining and flushing out old coolant and replacing with new coolant. What namebrand should I use? I am tired off giving all my money to the dealer so I am reaching out to everyone on this wonderful and informative forum.
Thank you,
BlAKE
Old Jul 31, 2011 | 05:39 AM
PGARRETT's Avatar
Cooling Fans 2006 Maxima
I am having cooling Fan issues. Started by suddenly no fans running at all, and of course no air conditioner, as far as i know if the Compressor is on the Fans should be running period. Then after turning the car off and sitting for a while it started working normally again and so did the airconditioner. Now the Compressor seems to work normally while the car is moving but if you stop in traffic it seems to stop blowing cold air even though the compressor light is on, and the car begins to heat up. I am suspect of the cooling relays since the first incident where i had no fans and no air even driving.
Any ideas how to narrow this down. the car has 63,000 miles.
I hate to give the dealer hundreds of dollars to replace a sensor or temp guage.
Miket2006
Mar 1, 2021 03:55 AM
captchaos
Mar 15, 2016 12:18 PM
RWCreative
Sep 21, 2015 11:01 AM
asianstyle
Sep 10, 2015 11:30 AM
