Aftemarket suspension and dealer warranty
Old Jan 16, 2011 | 12:25 PM
naMaxima07's Avatar
I have a 2007 Maxima with 26k miles. It is lowered with Tein springs. I have that annoying sound coming from the passenger side when i go over small bumps. Do you think the dealership will cover this under warranty even though I have aftermarket parts? Will they charge me just to look at it the next time I come in for an oil change?
Old Jan 16, 2011 | 12:35 PM
po8pimp's Avatar
yes. they will charge you because it is lowered on tein. I think you should have whoever put the springs on for you take a look at it. If the spring was not set correctly, then that will cause the noise.
Old Jan 17, 2011 | 12:03 PM
jsmithsole's Avatar
*moderator*
Yup what he said, they will look for any reason to not have to do warranty work. Plus it's not "their" problem anymore once you went aftermarket...
Old Jan 17, 2011 | 04:25 PM
NismoMax80's Avatar
SuPeRmOd
any parts unrelated to suspension, your warranty is intact. but with the springs you altered your suspension and they are the cause of the noise. so the dealer of course won't cover your suspension anymore... at least while those springs are on the car.
Old Jan 21, 2011 | 02:55 PM
syclonemax's Avatar
struts
all four struts went bad on stock 2006 max in the last three month's,, dealer said extended warranty won't cover it because it's goes under normal wear
Old Jan 21, 2011 | 02:56 PM
syclonemax's Avatar
only hase 23000mi
Old Jan 23, 2011 | 09:59 PM
NismoMax80's Avatar
SuPeRmOd
only hase 23000mi
that's not extended warranty. that's the original 36k warranty. call nissan directly. mine were replaced at 10k with a newer version.
Old May 7, 2011 | 02:39 PM
mateo420247's Avatar
If you replace the struts do not use kyb gr2...the quality control is horrible. Your almost guarenteed to get a bad strut and have to install twice...
user 11122324
42
Jul 18, 2022 03:35 PM
trsandrew
Apr 8, 2016 06:45 PM
knight_yyz
Nov 1, 2015 01:34 PM
trsandrew
Oct 25, 2015 02:47 PM
