Anyone using Mobil 1 Synthetic ATF instead of matic K?
Old Feb 6, 2011 | 06:08 AM
Kryogen's Avatar
I know alot of people use amsoil with success, but I wonder if mobil 1 syn atf is a good choice instead of matic K. I dont really feel like paying a hefty charge at the dealership if I can get synthetic at a lower price.
Old Feb 6, 2011 | 08:44 AM
NIKV69's Avatar
I have heard good and bad from Amsoil users. I decided to stay with K matic this cycle. I don't know anyone using Mobil why would you? If your going off K Matic Amsoil has to be better than Mobil 1. Their motor oil certainly is.
Old Feb 6, 2011 | 01:23 PM
Kryogen's Avatar
Heard some bad from amsoil users? Whats the bad?
Old Feb 6, 2011 | 02:35 PM
rohanmax14's Avatar
I did used mobil ATF 3 time but then I went back to nissian oem ATF.
Old Feb 6, 2011 | 07:08 PM
Kryogen's Avatar
I guess ill just get myself matic K and not bother...
Old Feb 7, 2011 | 06:40 AM
osisray's Avatar
i toyed around with this idea last month - but then changed my mind. I think i was saving a few bucks but didnt seem like it was worth the risk.
Old Feb 7, 2011 | 08:35 AM
NIKV69's Avatar
I think I read somewhere that Dexron III met D matic but not K matic. I also remember a couple of guys who thought they felt the shifting change a little when they put Amsoil in. I almsot tried it but the cost was the same. I woldn't touch anything but Nissan K or Amsoil for tranny.
Old Feb 7, 2011 | 06:24 PM
Kryogen's Avatar
Ordered 12 quarts of k matic from the dealer... :P I'll do the flush this weekend. Ill keep you updated w the results.
Dealer said there is no gasket for the pan that it's just permatex?
You guys re-sealed the pan w permatex?
Old Feb 7, 2011 | 07:12 PM
rohanmax14's Avatar
Don't do flush!! U taking a risk of tranny. Just do drain n refill n do other next day each time.
Old Feb 7, 2011 | 08:54 PM
NIKV69's Avatar
How you doing it? You have the machine?
Old Feb 8, 2011 | 03:40 AM
Kryogen's Avatar
Like in the "how to" of the fluid and lubricant section.
I'll drop the pan, clean it, clean the screen, clean the magnets, add 3-4 quarts. Then unplug the cooling tube out of the rad, start engine, let 2 quarts out, add 2 quarts. start engine, let 2 quarts out, add 2 quarts.
That way there wont be any solvents or anything bad going in, and everything will go the normal way, smoothly, and ill replace maybe like 90-95% of the atf.
Old Feb 8, 2011 | 04:48 AM
BronxSleeperMax187's Avatar
Used mobil syn atf on my 2000 gle..never had A problem in the last 30,000 miles using it....i'm at 149000
Old Feb 8, 2011 | 04:47 PM
rohanmax14's Avatar
lol look what year u drive compare to use n we both have different tranny that make a huge difference.
Old Feb 8, 2011 | 04:59 PM
rohanmax14's Avatar
@ Kryogen
let us know how did it go. Please take a pictures or "How to do it". If u can keep us update on how tranny running then before.
Old Feb 8, 2011 | 06:26 PM
KCMAXX's Avatar
KC's FINEST
subscribed
Old Feb 9, 2011 | 04:47 AM
Kryogen's Avatar
I'll take pictures.
Old Feb 10, 2011 | 05:39 AM
osisray's Avatar
nm
Old Feb 11, 2011 | 08:37 PM
up the middle's Avatar
I'm using mobil 1 syn tranny fluid. I have 15k since change and no issues. does seem to shift smoother
Old Feb 11, 2011 | 08:45 PM
rond310's Avatar
I have switched to Mobil 1 about 15k miles ago, no problems and smooth shifts so far. Maybe its my imigination but seems to shift smoother, especially in the cold mornings since making the switch. my Max is an 05 now with about 77k miles
Old Feb 12, 2011 | 03:21 PM
acercomp71's Avatar
Whole internet is flooded with transmission problems on this car already. Experimenting with changing OEM Nissan Matic K with aftermarket mobile atf or amsoil and whatnot is a bad idea. What you do is you put Nissan Matic K as prescribed by manufacturer and stop this discussion right now if you would please. Like I said people have enough problems with this transmission already, let's not make the situation even worse than it is.
Old Feb 13, 2011 | 08:19 AM
Kryogen's Avatar
Oh well, no ATF lines from tranny to rad in 5at. Hoses are coolant that run into tranny to cool it. No way to do the trick that was done on 4AT. No pan, no magnets(except on drain plug), no nothing.
Only thing you can do is drain and fill 3x I guess.
Old Feb 13, 2011 | 10:41 AM
Kryogen's Avatar
I did drain and refill 3 times, with a short 5 min run between drains.
First drain was all brown and seemed thick.
Second drain was still brown, less thick.
Third drain was red-brown, mostly liquid.
Took exactly 8 liters to drain 3x. 2.6 liters every flush.
Cant tell if tranny is smoother or not, it's snowing here so wheels slip anyway. I did not have major problems, but I expecienced rough shifts sometimes. Seems just fine.
There were some "bits" of stuff in the atf drained fluid, like friction material. Normal?
Old Feb 13, 2011 | 01:18 PM
Kryogen's Avatar
Having to throw away new atf cause you cant do a flush is a design shame for that tranny.
Old Feb 13, 2011 | 04:35 PM
05atxmaxima's Avatar
hey y'all, looking to replace the clutch on my 05 max with 6speed manual, any suggestions as to what type of tranny oil to use? also, is there a DIY guide to replace the guide?
Old Feb 14, 2011 | 05:03 PM
Kryogen's Avatar
Update: After 3 drains/refill, tranny is MUCH BETTER. Drove it hard trying to get it to slam and it just did not. WOT downshifts are smooth. everything is smooth. Looks like it solved my problem for now.
I drained a crapload of friction material chunks. Maybe that was all getting caugh in places it wasnt meant to. Anyway, I'll do one last drain/refill in like 3 months and thats gona be it, after that I guess ill do one every year.
Old Feb 16, 2011 | 01:04 PM
Truff02's Avatar
I'm going to drop the pan on mine this weekend. The dealer that replaced the trans right before I bought the car put some random *** fluid in it. Time to get that crap out of there.
Old Feb 16, 2011 | 07:40 PM
Kryogen's Avatar
There is no pan to drop unless it's a 4 speed.
Old Mar 30, 2011 | 10:28 AM
DMAXI06's Avatar
I really want to do this, but in a normal 5at how much fluid will come out upon draining??
Old Mar 30, 2011 | 10:42 AM
ubersl's Avatar
Did drain and refill 2 weeks ago. Drained exactly 5 quarts.
Old Mar 30, 2011 | 02:51 PM
maxlk's Avatar
i'm using mobil1 and havent had any issues so far 85k miles.
Old Mar 30, 2011 | 09:14 PM
DMAXI06's Avatar
THANKS
Old Mar 31, 2011 | 03:46 AM
Kryogen's Avatar
2.6 liters every drain. 3 times. used nissan K matic. Shifting is way better now.
Bought a case of 12 liters, so I got 4 left after 3 drains. I'll do a last one soon, and keep 1 for touch ups I guess.
I think I'll do a drain/fill every 30 000km now.
Old Mar 31, 2011 | 09:53 AM
tweets04's Avatar
I have an 04 that wasnt taken care of by previous owners. I read that you cant flush these and thats probably a big reason they got so many problems. Im glad to hear that just a drain and fill helps them out a lot, looks like I got something to do this weekend lol.
Old Apr 2, 2011 | 06:02 AM
Kryogen's Avatar
not one, 3. Make sure car is fully heated before first drain. Drove 5 min in between, switching all gears. Stay on reverse for a while.
First drain was thick and black, 2nd was better, 3rd was starting to have some pink. Shift is definitely better.
I will do a 4th drain and fill soon cause I have some spare fluid.
Old Jan 13, 2012 | 10:41 AM
Safiloo1's Avatar
Drain and refilled mine with Matic K, it took 3.5 quarts. My advise, use the Matic k, if Nissan its that persistant in use that oil, use it. you know all the horrible stories about our trannys. my 2 cents..
Old Jan 14, 2012 | 05:25 PM
Truff02's Avatar
What'd that cost you? That stuff isn't cheap.
Old Jan 14, 2012 | 05:43 PM
BadBlackMaxSL's Avatar
I went to Conrads GoodYear and I had all of my trans fluid sucked out and replaced with QMI Synthetic about 6 months ago when i was at @71,000 miles. My old fluid was dark but without any metal shavings. I did the drain and fill at 60,000 and it helped but not by much. Now the shifts are smooth, when warm it's like a CVT, I can barely notice any shifts. The harsh P-R shifts are gone and I rarely get the hard 3-2 down shift, mostly if the trans is still cold. I went with synthetic over the Nissan K Matic because the trans were failing with Nissan's and it was the best fluid on the market for these trans when it rolled off of the assembly line. Since 2003 these synthetics have been developed and produce superior results and performance. I will not have to touch this fluid for 40,000 more miles, I'm at 81,000 now and feel very secure in my research, decision and results. The cost was @$110 for the service. Go to qmiitw.com to read more on this product.
Old Jan 14, 2012 | 06:25 PM
Truff02's Avatar
Funny story, I used to work at the Conrad's in Rocky River and made trips to the FP location all the time. It's been a very long time though but that's where I got my start in the automotive industry.
Old Jan 14, 2012 | 07:04 PM
That's the one I go to!! On Center Ridge. They do a good service at a good price, oil change for $19! They also replaced my AC hose for me for around $100, IIRC.
Old Jan 15, 2012 | 09:27 AM
timpol's Avatar
I switched to M1 at 105,000. Marked improvement across the spectrum in terms of shifting, R-D gear change, etc. I'm at 172,000 today and have had no issues. The improvement at 105,000 is more due to the fact that the trans fluid had never been swapped before than a K-Matic versus M1. I'm happy with M1 and it's easily available at the auto parts store.
