timing advance
Old Mar 12, 2011 | 02:17 PM
twentyeggs's Avatar
timing advance
interesting enough there isn't a thread about timing advances on this forum. just think its something people would be interested in since its literally about 50 bucks and a great easy fast mod for more power.
i guess i can start this one off by asking who has got their timing advances and by how many degrees.
also tell us what you think about it. Worth the time, money, what kinda gains you think, noticeable?
any dealer, performance shop will do +2 on your stock car. if you wanna do more you need a module or flash.
Old Mar 12, 2011 | 02:20 PM
6.5affiliate's Avatar
Just wanted to note that if you exceed 2+ on the timing advance than it won't stick.
Old Mar 12, 2011 | 02:27 PM
hero782's Avatar
+2 is what's recommended. For any socal ppl I can do the advance timing for $25
Old Mar 12, 2011 | 02:45 PM
Shift_A32B's Avatar
Can advance timing be done on 4th gens...sorry for the noob question. I might consider this.
Old Mar 12, 2011 | 03:15 PM
hero782's Avatar
I can only do 6th gens and up. It's done thru the odbII connections. I think you can advance the timing on 4th gens but I wouldn't know how
Old Mar 12, 2011 | 03:19 PM
Oolatec's Avatar
You won't see any benefit.
Old Mar 12, 2011 | 03:41 PM
twentyeggs's Avatar
that's right +2 is the highest you can go, the second you turn your car off it will go away. you will need a module if you want it to stick
Old Mar 12, 2011 | 03:43 PM
twentyeggs's Avatar
just pm'd you. would like to check out your car too. haven't seen a decently modded max in person yet.
all i have is a cai, and a exhaust e-coutout. so far..
Old Mar 12, 2011 | 06:28 PM
LiquidEliteMax's Avatar
Will the timing advance shorten the life of the engine?
Old Mar 12, 2011 | 07:18 PM
dstruc's Avatar
50 bucks? i paid 10.
Old Mar 12, 2011 | 07:53 PM
Oolatec's Avatar
No. But you won't see any benefits either.
Old Mar 12, 2011 | 07:59 PM
locknuts27's Avatar
You can do the time advance but it won't stick once you turn the ignition off. It gets erased on 4th gens!!!
Old Mar 12, 2011 | 08:07 PM
twentyeggs's Avatar
why do you keep saying that? don't listen to him, obviously he doesn't now about the mechanics of a combustion engine. timing has a drastic effect on cars. manufacturers time our engines to burn the fuel per cylinder cycle more completely to get better emissions but less performance. whoever oolatec is he is not anyone to listen to. timing advance is a major factor included in a performance tune for a reason, because it WORKS... it isn't like slapping on forced induction, but in the list of mods together it is one more piece in the performance puzzle.
it especially works in conjunction with other mods. if you did a timing advance in a bone stock car, you probably won't notice anything other then a smoother acceleration during WOT and a little bit more responsiveness.
oolatec please get off my thread until you educate yourself in the simplistic function of our engines. misguiding people who look to us for information is not what this forum is about.
Old Mar 12, 2011 | 08:19 PM
twentyeggs's Avatar
to correctly respond to this question, the short answer is no, the modifications that you should worry about shortening the life of your engine are mods that introduce significant power increases like forced induction, NO2, CAI+exhaust+performance tune, basically it goes like this, the more power you squeeze our of your car the less the life expectancy. BUT, anything other then forced induction and NO2 will not shorten the life of your car by much, we are talking over 250,000 miles (given you are routine with your maintenance) and are you really considering keeping your car till it konks out? that could be over 15 years. i don't know about you but i don't plan on driving this same car in 5 years. If you slapped on every performance enhancing part made for this car, (except nitrous) your life expectancy wouldn't be so short that it would die on you before 250,000 miles. NO2 is the only thing that significantly shortens the life of your car.
in short do not worry about this. odds are something totally unrelated will happen to kill your car off before a performance related thing does.
there are exceptions, but there are also asteroids falling toward the earth at thousands of miles an hour
Old Mar 12, 2011 | 08:28 PM
locknuts27's Avatar
Unfortunately this mod isn't ideal for 4th gens as the timing is erased every time the ignition is turned off and turned back on! Of course if he decides to get an e-manage.....
Old Mar 13, 2011 | 11:22 AM
Oolatec's Avatar
Show me before and after dynos after having this done.
I thought so.
I had the timing done to my car, and it didn't make one bit of difference. It's a gimmick. Just because you can "tweak" something, doesn't mean it has any benefits.
You asked for input, and I gave it.
Old Mar 13, 2011 | 12:32 PM
twentyeggs's Avatar
i am not going to dyno my car to prove you wrong. I can't believe i am doing this search for you
http://auto.howstuffworks.com/ignition-system1.htm
just because you don't have the sensitivity in your body to measure G force differences in factors less than 1 doesn't mean it didn't do anything for your car. I already stated above that it isn't the best mod. if you used that mentality for all the mods available for our maximas you wouldn't have sh^t done because 1 singular mod isn't going to make a difference. a list of mods together is what does something. 1 person can't elect a president. but collectively people can, and that president aka. list of mods, WILL make a large difference. unless its obama then all your mods are just going to sit around saying they will do something but instead raise the national debt to unheard of figures with no result. obama mods won't do anything for you car.
so stop being do dam ignorant, do your research and stop making a fool of yourself. most of us knows its fact that these timing advances work to our benefit and complement the existing mods on our cars.
Old Mar 13, 2011 | 12:51 PM
Oolatec's Avatar
I am not the one making a fool of myself. The dyno doesn't lie. If it's such a "great/easy" mod, then show us proof that it works. I had full bolt-ons on my '04. headers, full exhaust, NWP spacers/BOP/intake. Pretty much everything available at the time. As well as the timing advance. Didn't make one bit of difference.
You aren't going to dyno your car, because you know deep down inside it makes no difference.
You can post all the links you want, but people want real-world results before forking over any $. Even if it's $50. And last I saw, there were no before-after dynos done that proved the timing advance did anything.
Old Mar 13, 2011 | 01:02 PM
Rods03Max619's Avatar
Wanted to do this but oh well and don't know if people feel a major difference or what.
Old Mar 13, 2011 | 01:08 PM
twentyeggs's Avatar
im not going to dyno my car because i don't have a set of rollers sitting in my garage. it would cost more then 50 bucks to put up a before and after map.
your stupid dude. you saying timing doesn't help is like saying anything more then 2 valves per cylinder is redundant. its complete bull****. and like i said before you are basing your "decision" on whether or not you can "feel" extra g forces that is like weighing a ounce on a bathroom scale. NO **** YOU CAN'T FEEL IT SHURLOCK!!!! it takes 16 ounces (aka. list of mods) to equal a pound (aka a noticeable difference). when the REAL maxima enthusiast and motor heads take our cars to the track where a 1/10 of a second is a BIG DEAL a timing advance equates exactly that. a BIG DEAL in the engine tuning mod.
FUC* off dude. this is the last post i send you, say whatever you want. your an ignorant bastard
Old Mar 13, 2011 | 03:13 PM
twentyeggs's Avatar
here's another source proving performance out of timing.
quote "Our dyno days show that there is a correlation between advancing the timing and an increase in low-end torque"
http://www.miata.net/garage/KnowYourCar/S10_Timing.html
Old Mar 13, 2011 | 05:26 PM
Reizy's Avatar
On a 5.5 gen but:
http://forums.maxima.org/all-motor/4...ive-proof.html
Old Mar 13, 2011 | 06:47 PM
Oolatec's Avatar
Originally Posted by Reizy
Thanks for that. And it just proves my point. There is no benefit. You're not going to notice that. I bet they did a few more runs without the +2 timing, they could get the same numbers.
Now if the car were pushing 12 lbs of boost...
Old Mar 13, 2011 | 06:52 PM
Oolatec's Avatar
Didn't know this was a Miata board. lol
2HP isn't going to make one bit of difference.
Old Mar 14, 2011 | 05:12 AM
the macedonian's Avatar
I have had this done and it I must agree, the mod alone will NOT show you any increase at all, HOWEVER, once you add other mods you should see some benefit. I am tempted to do a dyno before TA and after just to see if there is any improvement as this thread took a wrong turn like 10 posts into it
Old Mar 14, 2011 | 02:09 PM
twentyeggs's Avatar
thats right, we got a bunch or amateurs who don't know jack crap about cars walking about all butt hurt because the TA they did to their cars didn't feel like a turbo. go cry me a river and find another thread to b!tch on.
Old Mar 14, 2011 | 02:58 PM
Oolatec's Avatar
LOL @ calling me an amateur. You asked for thoughts, and I gave you mine. You disagree. The dyno results prove my point. Quit crying about it.
Old Mar 14, 2011 | 08:36 PM
dpeles1's Avatar
So it resets when you turn the car off?
Old Mar 14, 2011 | 09:28 PM
lowbudget's Avatar
i have access to a scanner at the shop i work at, how would i go about advancing timing?
Old Mar 16, 2011 | 05:26 AM
HMAX08's Avatar
Depending on what year you have, you NEED a CONSULT II that nissan has, to my understanding a regular scanner cannot up your timing. NOW for 07-08 an CONSULT II WILL NOT WORK (i tried) Maybe a Consult III would work not sure. you WILL need the bully dog powerpup for the 6.5's
My friend did the advance for me on his bully dog, I did feel a slight difference in the beginning (i just had a SRI) I have no other bolt on mods yet, now maybe i got use to it but i dont really feel a differnence now again maybe i got use to it or my butt dyno is not working, LOL.
I will be adding the NWP spacers with BOP soon so maybe that will help
Old Mar 16, 2011 | 06:40 AM
locknuts27's Avatar
4th Gens it resets, 5th gens and on will stick....
Old Mar 16, 2011 | 07:33 AM
dpeles1's Avatar
Cool. Thank you.
Old Mar 21, 2011 | 11:49 PM
Oolatec's Avatar
Of course when you add the spacers and BOP, it'll help... but the timing advance has nothing to do with it. I had full bolt-ons on my '04, and the timing advance didn't make any difference.
Old Mar 22, 2011 | 05:13 AM
HMAX08's Avatar
It was done for free, so i said why the hell NOT. Waiting to get a nice damn day here to add those freaking spacers and bop, lol.
Slightly off topic, i have a nismo SRI and has my stock grill on, the other day i added the E&G classic mesh grill, which basically opens up the front and I swear i feel a little more oomph, maybe more air in getting in i dont know but the car has a little more pep in its step. Again those are feelings and we all know that those can be tempermental
Old Mar 22, 2011 | 10:43 AM
dpeles1's Avatar
I felt a difference too when I put my street scene grille on.
Ben2003GLE
31
Jul 17, 2016 08:13 AM
kmitchel
Oct 28, 2015 09:46 AM
Starrider
Sep 17, 2015 07:26 AM
rbaker100
Aug 31, 2015 11:09 AM
305head
Aug 26, 2015 09:03 PM
