04 5AT trany problem
hi every one
I got this issu for 4 days now . when shift from P,R,N to D it pushs like some one hit me from back . but I dont see any problem while driving .
I went to a local workshop and they told me that the transmission is dying .
we dont have any 5AT here in Saudi Arabia . I cant replace it so I might rebulid it .
any thing could help ?
hi every one
u can try a bottle of transmission treatment for an autoparts store for the meantime, but the guy is right. the transmission is going out. you will need to rebuild it if that's your only option. Good luck, not even i would actually go for it and rebuild a transmission out of this car.
Damn....another maxima did hit the fan...
Buddy, just don't release the clutch/brake pedal until your gears completely engaged before you take off. That will save some hard bangs on your transmission. Try to drain/refill fluid at least once if not twice. These are all methods to borrow more time until your transmission goes out. Read the sticky for transmission fix. You will find all kind of answers.
http://forums.maxima.org/6th-generat...ssion-fix.html
how long do I have ? and I couldn't find matic K fluid . I found J and D and C
that happend only when I drive to and from my work wich it is Away from home 1hour on the highway .that means when the fluid become hot .
hi every one
check your motor & transmission mounts, they might be bad.
the only think I can tell you is to order online.
you are going to need buy 4 qts, but you are only going to use 3 1/2. if you want to do change the oil.
Did you check your fluid, is it red or brown?
by the way, what year car?
http://cgi.ebay.com/ebaymotors/MATIC...Q5fAccessories
the oil is brown . and the car is 2004
The oil is the cheapest thing you can do.
Remember you said the car drives fine, it's just when you are changing from P R N D.
That says mounts all the way, oil change is a good idea because you want that tranny lubricated constantly.
Good luck.
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
