Power Steering Leak
Power Steering Leak
So my buddy has a 6th gen that is now experiencign so power steering fluid leakes. He tried taking it to a local mechanic which has proven to be unsuccessful. He is trying to avoid taking it to the dealer if he can just find a starting point. Has anybody experienced problems with the power steering before? Any insight would be extremely appreciated! Thanks
I had a similar problem. Someone that had the car previously didnt put the High Presure line onto the bracket at the back of the intake manifold and caused the high power line to leak at the brass fitting. If the puddle is consistant in size thats what it can be. Unfortunately the line is more then the pump so see if the leak drips from the rubber housing on high pressure line.
would it look like oil on the floor? if power steering is leaking? because when its wet i see a lil oil puddle i just had my timing chaing and everything done but i remember fbefore they did that i was leaking power steering fluid from the pump by passanger axle
lowpost99
Oct 26, 2025 06:53 PM
Mar 12, 2020 12:06 AM
ag90fox
Sep 9, 2015 12:22 PM
