LED mod
Old May 17, 2011 | 06:25 PM
MadMaxx11225's Avatar
LED mod
anyone know where i can get a step by step guide on installing some under dashboard LED lights
Old May 18, 2011 | 09:11 AM
BOOTZ's Avatar
You're not gonna find one. Good luck tho!
Old May 18, 2011 | 09:31 AM
officerfrasher's Avatar
Under dashboard as in the footwells? I bought these strip lights:
from this thread http://forums.maxima.org/6th-generat...8022-leds.html and installed them. They're plug-n-play and have an adhesive back. I plugged them in, stuck them up on the bottom of the dash and was done in less than 10 minutes. And they're really bright!
Old May 18, 2011 | 10:55 PM
yes those were the lights am looking for, i have some but they not plug and play like that and its gonna cost me 80 to install with a swtich.
Old May 19, 2011 | 09:03 AM
NismoMax80's Avatar
SuPeRmOd
those "plug-n-play" end are less than $1 online or some stores, just splice and insert.
when you pop out the bulb (which is a pita for the passenger side) simply insert the strip with the end. if it doesn't work, remove and switch it.
why do you want a switch? if you really want one, look up relays.
$80 should include quality strips and a perfectly clean install.
Old May 19, 2011 | 10:00 AM
jowo9's Avatar
Just splice into a power source and wire up a switch wherever the heck you want it. Not hard and the switch will cost you $10 at MOST.
Old May 24, 2011 | 08:22 AM
06silvermax's Avatar
I have a led kit that i installed. But i might get these to use when the car door is open
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
