Bleed Master Cylinder
Old Jul 25, 2011 | 04:20 PM
eK9aT10pSi's Avatar
Hey guys, anyone have some insight on the easiest way to bleed the MC?
found this on the 4th gen: http://forums.maxima.org/7788803-post8.html but they have more hard lines than ours.
I bought the complete rotorpros brake kit with hawk hps pads and ss lines a while back but they were/are leaking so i got a new set of goodridge ss lines so when i replace them, i want to bleed everything as braking is worse than stock.
TIA
Old Jul 25, 2011 | 05:26 PM
po8pimp's Avatar
I would suck out what you can from the top, because it is the quickest, then open one line and bleed it dry, then do the others until all are replaced. You need to follow the service manual. If you need a copy I can post it for you . The ABS fuse needs to be pulled along with the negative battery terminal.
Old Jul 25, 2011 | 05:30 PM
po8pimp's Avatar
http://www.mediafire.com/?hoz3ubeta351suu I think what you are looking for is on page 8. As always scan file with a virus checker prior to opening.
jmlee44
Oct 2, 2022 02:13 PM
knight_yyz
Nov 1, 2015 01:34 PM
dshinn
Sep 26, 2015 08:07 PM
