Advice on changing PCV valve?
Old Dec 17, 2011 | 12:23 PM
mrjasonlyrics's Avatar
I never did any kind of servicing what so ever on my car for the 4 years i've had it and i'm looking to get on that before it cost me money.
I just bought a pcv valve for my 04 maxima but I don't have a clue about my engine. I'm not gonna take it to a mechanic to have them charge me a 1hr labour for something that looks so simple.
The thing is I have no idea where it is . If there's a thread of pics please let me know. I'm sure it's probably a simple job and i'm not a novice when it comes to working on my own car. Thanks
Old Dec 17, 2011 | 12:37 PM
BigLou55's Avatar
im not sure of its exact location but I would suggest start looking on the rear valve cover its where ive seen em on 4th and 5th gen maximas...good luck and yea its definitely a simple replacement no need for a mechanic
Old Dec 17, 2011 | 12:42 PM
I'm assuming I have to take off the engine panel? I don't want to waste time to go to the dealer and ask them. It looks simple but i'm sure getting to it would be the task
Old Dec 17, 2011 | 02:29 PM
maxfever1987's Avatar
If your standing in front of the car, its towards the rear right side/rear passenger side of the car, a black hose is going right onto it, this should help you out
http://www.justanswer.com/nissan/47n...-2-nissan.html
Old Dec 17, 2011 | 06:49 PM
Thanks man. It looks like a simple job.
Old Dec 17, 2011 | 11:21 PM
NIKV69's Avatar
Yep I did mine when I did the plugs but it seems just as easy without taking off anything.
Old Dec 18, 2011 | 03:10 PM
infinimax96's Avatar
The PCV valve is on the Valve cover. Right on the top. A hose is attached to it. You need to remove the hose clamp and pull the hose off, once you get the hose off you can remove the pcv and replace with a new one.
If you can't find it with the image provided, I'd seriously recommend you take it to a professional before you start pulling random hoses and cause yourself more problems.
Old Dec 18, 2011 | 03:17 PM
My strut tower bar is blocking it so the next thing i'll do is remove is then the panels,that way i'd have a little better vision. Now that I know exactly where it is it shouldn't be a problem.Appreciate the help
Old Dec 18, 2011 | 03:26 PM
Rods03Max619's Avatar
Good luck...
Old Dec 19, 2011 | 04:24 PM
It turns out the pcv valve on the 6thgen maximas are a pain in the ***. I asked a dude who works there and he said due to the lack of space to work i'll have to remove the IM to get more space.
That's a major set back. Oh well i'll do that along with the spark plugs when I install the spacer seeing that most of the stuff will be off anyways. Every other car I changed the pcv valves on it was in plain view. Nissan made it hard so that you bring it back to them. LOL. I can't really do all that now because we're in the -0 degrees
Old Dec 20, 2011 | 03:34 AM
Kryogen's Avatar
you dont have to remove the im collector. it makes it easier but you dont have to.
Old Dec 20, 2011 | 04:28 AM
I didn't expect it to be such a pain. I'm not affraid to attempt it but we're in the -0 and colder so if it's gonna take long I'll leave it for when I install the BOP,spacers and spark plugs.
I'll attepmt to change it without removing the IM
Old Dec 20, 2011 | 07:15 AM
NIKV69's Avatar
Which is why you replace the PCV when you do the plugs and have to take the collector off.
Old Dec 20, 2011 | 07:27 AM
Has anyone ever change their PCV valve on the 6thgen maximas? I just want to know if it can be changed in less than an hour without taking off the I'm or other time comsuming components. If it was warmer I'd get in there but my fingers will freeze off before I get to it.
Old Dec 20, 2011 | 07:32 AM
NmexMAX's Avatar
dot dot dot ...
6th gen = 5.5 gen, same set-up. Removing the IM shouldn't take more than 15 minutes. Takes me less since I have removed everything that gets in my way (VIAS).
It can be done with out removing it, but it is tight and you'll need to remove other items (i.e. strut bar, plastic crap/coverings, etc).
Old Dec 20, 2011 | 10:03 AM
I wouldn't say same set-up, I'd say similar. There's a pic above, I don't think it's a 6thgen. It looks more like a 5thgen and I'n mine I can't fit my hands anywhere in the back there.
I'll try removing the strut tower bar and see if I can fit my hands. I'll let you all know
Old Dec 20, 2011 | 10:19 AM
CRiME's Avatar
oem ftw!
Check out this thread for a little more info and tips on the PCV replacement. Apparently there are some differences in the 5th gen and 6th gen replacement procedures. Seems like it's easiest to do it with the manifold off, but people have done it without removing the manifold.
http://forums.maxima.org/6th-generat...ion-valve.html
Man, I changed my plugs last year and completely forgot about the PCV. Well, I guess I'll be waiting a few months until things warm up before I take that UIM off again. Guess I can use this as an excuse to install the spacer kit
Old Dec 20, 2011 | 10:28 AM
NmexMAX's Avatar
dot dot dot ...
I've done them both and the only thing different is the engine cover and VIAS cover on 07+.
In fact, that cardomain pic is from a 5.5 gen.
Old Dec 20, 2011 | 11:06 AM
My original plan was to change it but I guess I might have t wait until my BOP,spacers and spark plug comes
Old Dec 20, 2011 | 11:10 AM
Did you change the pcv valve on the 6thgen with the I'm on or off? And I had a mind that was the 5thgen pic. That looks way more roomy compared to mine
Old Dec 20, 2011 | 11:59 AM
MadMax07SL's Avatar
I did mine a few months back. Took off the cowl cover and metal shroud. Not knowing exactly how it came apart, took about 1.5 hours from start to finish. Knowing what I know now, would be done in less then an hour to do it again...
Old Dec 20, 2011 | 12:08 PM
NmexMAX's Avatar
dot dot dot ...
If I had a penny for everytime I've used that term with these cars. Seriously though, practice makes perfect.
Old Dec 20, 2011 | 05:07 PM
Kryogen's Avatar
Ok im out of that retarded thread.
Just change your ****ing valve and stop asking about it. What kind of fagness is this.
Old Dec 20, 2011 | 05:10 PM
Dude take a chill pill. I got the info I needed
Old Dec 20, 2011 | 06:29 PM
NIKV69's Avatar
Are there any mods on this site?
Old Dec 20, 2011 | 07:39 PM
There's a lot,just go to the forum and go in Group deals/Sponsors forum in green and you'll find parts for sale.
Old Dec 21, 2011 | 08:37 AM
NIKV69's Avatar
LOL, I meant moderators. LOL
Old Dec 21, 2011 | 09:03 AM
SmokinMax02's Avatar
Changed my PCV in about 20 minutes with a good pair of long needle nose pliers and a little patience. Didn't have to remove the IM or Strut bar. Screw all that.
Old Dec 21, 2011 | 11:20 AM
NmexMAX's Avatar
dot dot dot ...
I agree though, change it and report back. Tell us of any issues, etc.
tgreen
Oct 18, 2015 06:18 PM
Max139617
Sep 20, 2015 07:25 PM
Max139617
Sep 20, 2015 07:09 PM
DarjeelingRose
Sep 15, 2015 01:20 AM
tardrex
Sep 11, 2015 07:35 PM
