BOUT TO HIT 100K
Old Jan 16, 2012 | 07:36 PM
embitious's Avatar
BOUT TO HIT 100K
well like it says, am bout to hit 100k, what do you think i shoud start replacing as of now, what mantenace did you have to do when you hit 100k
Old Jan 16, 2012 | 07:43 PM
BigLou55's Avatar
is that mileage MAINTENANCE interval in your owner's manual?
Old Jan 17, 2012 | 04:40 AM
infiniti medic's Avatar
Spark plugs, cabin filter, and change trans fluid. Those are the important things. Don't forget engine oil and filter.lol
Old Jan 17, 2012 | 05:13 AM
mrjasonlyrics's Avatar
I'm at 214K. What ya'll drive like a few km a day and park the car during the winter or something. I guess you might want to change your spark plugs, PCV valve, do your regular oil changes, replace filter, coolant flush, brake flush, tranny flush if you really in that zone but you should be good with just the first few
Old Jan 17, 2012 | 05:58 PM
DeusExMaxima's Avatar
remember to get a pic of the big moment and post in the sticky
Old Jan 18, 2012 | 02:36 PM
Burny's Avatar
When are most of you replacing the water pump, tensioner, idler if at all? I know the timing chain is good for a while.
At 100k I would also replace the 2 drive belts
Old Jan 18, 2012 | 06:13 PM
embitious's Avatar
am hearing a rattle noise during cold starts, and am hearin that i have to replace the timing chain, any comments on that??
Old Jan 19, 2012 | 05:34 AM
Burny's Avatar
I think there is a little plastic bracket associated with the timing chain that causes all that noise. I have searched "timing chain" on here and read about it in the past.
Old Jan 20, 2012 | 12:18 AM
SilverMax_04's Avatar
I did not replace my plugs until 120 K miles because my gas mileage was about the same as it had been at 50 K miles. It stilll did not get bad at 120 K, but I thought I had pushed them far enough. See the spart plug thread here for more of my experience with them.
All of the above suggestions are good. The one thing that has been left out of the lists above are the large hoses connecting the radiator to the engine. I replaced mine when I changed antifreeze. The thread on that replacement in the "Fluids and Liquids" section of this site is helpful for that antifreeze replacement. I bought Toyota antifreeze here cheaper than the Nissan brand was going for and used that - is should be Jap antifreeze, per that thread.
Good luck.
Old Jan 26, 2012 | 06:16 AM
moNYtx's Avatar
I'm about 2,500 from hitting 100k, change all the regulars, filters and fluids.
D Mason
Jun 21, 2016 04:43 AM
captchaos
Mar 15, 2016 12:18 PM
doctorpullit
Dec 12, 2015 09:39 AM
Dennis Twohy
Oct 1, 2015 06:01 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
