2007 motor in 2004 maxima
Old Apr 10, 2012 | 08:18 AM
maxam's Avatar
Good day everyone
What do I have to do to install engine from 2007 maxima in 2004 ?
Is there any deferences between them ?
Because my old engine is dead . I got a new one from a totald 2007 with low milage.
Old Apr 10, 2012 | 08:47 AM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by maxam
Good day everyone
Will drop right in.
Old Apr 10, 2012 | 10:51 AM
maxam's Avatar
Originally Posted by NmexMAX
Will drop right in.
But the mechanic sayed that I have to change the oil pan in order to install the starter in it's right place . because I have 5spd transmission .
Old Apr 10, 2012 | 10:58 AM
NmexMAX's Avatar
dot dot dot ...
5AT vs the CVT. He might be right. I forgot about that.
Old Apr 10, 2012 | 02:07 PM
L36's Avatar
L36
I have a 07 motor in my 04. Bolts right up to the 6 speed. If it bolted up to my 6 speed, it will certainly bolt up to a 5 speed A/T.
The upper block is slightly different but it will work just fine.
You don't have to change anything, no oil pan; nothing.
Old Apr 10, 2012 | 02:40 PM
NmexMAX's Avatar
dot dot dot ...
The bolt pattern for CVT's and 5AT's are different than the 4AT and 6MT's, which further proves that the 5AT and CVT equipped engines/tranny's are a match made in heaven.
http://forums.maxima.org/8418944-post17.html
Old Apr 10, 2012 | 06:23 PM
L36's Avatar
L36
Well in my case, the 07 motor bolted up to my 6 speed just fine. Thus i did not know 5 speed and 6 had different bolt patterns.
Old Apr 11, 2012 | 07:52 AM
maxam's Avatar
so I'm the frist one who installd 07 motor in 04 maxima with 5 A/T ^_^ .
now only axels and intake manifold left . tomorrow I will start the engine .
Old Apr 11, 2012 | 08:11 AM
NmexMAX's Avatar
dot dot dot ...
Why the manifold?
07+ is plastic, but it's the same thing though. Nothing different.
Old Apr 11, 2012 | 08:27 PM
L36's Avatar
L36
You should of done the tensiones while the engine was out. They're bound to wear out if not replaced.
Finkle
Sep 27, 2015 09:53 PM
BobMax
Aug 15, 2015 12:35 PM
soon2ownmax
Aug 13, 2015 02:19 PM
criminalslang810
Aug 9, 2015 03:35 PM
silver_i35
Aug 3, 2015 11:20 PM
