new engine installed,CES and ABS lights are on !!
Old 04-15-2012, 01:01 PM
maxam's Avatar
good day everyone
I have installed new engine on my 04 SE 5spd , now I heve the CES and ABS light on .
see the last code !! what does it stand for ?( C1107 )
maxam is offline
Old 04-15-2012, 03:27 PM
L36
L36's Avatar
Check all your fuses. P0037 is the o2 sensor behind the car in bank 1, check if the sensor is not damaged or shorted. Might also be a bad cat, but if the code instantly appears right after clearing, its most likely either a bad sensor, or damaged, shorted wiring somewhere.
ABS, check fuses, relays. Does the pump run while engine is off? If it does, you got a bad ABS pump. You can have a bad ABS sensor at one of the wheel hubs, there is a way to read ABS codes if you have consult or there is a method reading a ABS light, check the FSM.
L36 is offline
Old 04-17-2012, 07:29 AM
maxam's Avatar
I can hear the sound of ABS pumping and the light comes on when I start the engine and drive it about 10 meters .
I will check the other issues with the workshop that have doen the job . it might be just some dirty plugs and need to be cleand .
maxam is offline
Old 04-17-2012, 07:27 PM
nsnrider's Avatar
if you had no abs problems before the engine swap and came up with abs codes after the engine swap then i would check over your work like the front abs sensors/plugs. and all abs connectors under hood and fuses.
nsnrider is offline
Old 04-21-2012, 09:26 AM
maxam's Avatar
I have checked and dis & reconnected every plug and fuses . nothing happend
maxam is offline
Old 04-24-2012, 10:58 AM
maxam's Avatar
it seems to me that I should replace them . can any one give there part number ? so I can buy the right sensors
maxam is offline
MaximaDrvr
08-19-2015 08:20 PM
2k0to2k3
08-18-2015 09:59 AM
Viralkill
08-17-2015 10:54 AM
Viralkill
08-16-2015 05:09 PM
Quick Reply: new engine installed,CES and ABS lights are on !!
