A/C display not working
Old May 7, 2012 | 08:01 AM
alwayzast3pah3ad's Avatar
Hey, Im new and I need help. My a/c works fine, it wont display temperatures, fan speed everything in the little top screen. Then on the info display it wont show outside temperature saids 0 but will display radio channel time everything else.
Old Oct 15, 2013 | 08:43 AM
HighFlyerMN's Avatar
I am having the exact same problem with mine. I have tried unplugging and plugging each wire harness back in and also disconnected the battery in an attempt to reset the computer but nothing has worked. I'm ready to take this to the dealer The worst part is that everything worked until I took it apart to see about installing an aftermarket head unit. When I decided to wait and put the dash back together I lost that upper display and my dash says its 0 degrees and icy.
Old Oct 15, 2013 | 10:38 AM
po8pimp's Avatar
there are mulitiple plugs associated with the "brain" of the display unit. Open back up and check that you connected all plugs. I would also recommend checking the fuses. If both are good, disconnect your battery and reset the BCM. Sometimes it hangs up and things don't work correctly. Might need reset.
Old Oct 15, 2013 | 11:32 AM
Thanks for the reply. I have taken the radio, climate controls, etc. out again and double checked the plugs. During this time I also disconnected the battery twice for about 10 minutes each time. Do I need to leave it sit unplugged longer than that? Any idea what fuse it could be? I took a quick peak at the fuses and pulled a few that I thought it could potentially be and all were good. I was going to put in an Alpine HU and I bought the adapter to keep the functionality of the stock display but I never got that far to plugging anything in and now I'm afraid to touch it. This isn't my first rodeo either for radio installs.
Old Oct 17, 2013 | 07:33 AM
smplyamzng's Avatar
did you ever resolve??
curious as to how it turned out
Old Nov 4, 2013 | 09:52 AM
I have not resolved this. I took it to a buddy shop where I know some of the workers and they put it on the scan tool but couldn't pick up any related codes or issues. He said it was like the BCM wasn't there
Old Nov 4, 2013 | 10:10 AM
CALIMAX06's Avatar
http://my6thgen.org/f64/08-maxima-bo...install-16819/ Take a look through this link. A couple ppl in here had ur same problem and seem to have resolved it. Hope this helps
Old Nov 4, 2013 | 03:06 PM
po8pimp's Avatar
At this point sounds like Nissan for a diagnostics might be your best bet. I have taken the head unit out multiple times without any issues except when I installed the aftermarket head unit and hooked the black wire to the black wire on the harness instead of a ground on the chassis. I gave up and went to Nissan.
Old Nov 5, 2013 | 07:44 AM
This must be it!! Thank you very much, I will dig into it again. I have that NIRD01 unit but was afraid to mess with it after this fiasco.
Old Nov 5, 2013 | 09:52 AM
po8pimp's Avatar
So from reading that link it could be the wrong plug in the back of the display?
Old Nov 7, 2013 | 12:48 PM
That's what I gathered. I hope to look into it tonight. I'll report back if it's fixed.
Old Nov 8, 2013 | 09:47 AM
Well, that didn't work. They must have been referring to an extra plug on the NIRD-01. I took my dash apart again last night and there was no extra plugs hanging back there and believe me, I looked. I've found a used BCM for $40 but I hate to start throwing parts at it without knowing what it is. It's either that or off to the dealer.
Old Nov 8, 2013 | 03:15 PM
CALIMAX06's Avatar
Well like po8pimp said, you should just take it to Nissan for a diagnostics. That way you wont be throwing your money away on the wrong parts
Old Mar 17, 2014 | 07:38 AM
Well I broke down and bought a used BCM off Ebay and hooked it up this weekend and it was NOT the fix. It's still doing the same thing so I guess it's off to Nissan.
Old Apr 11, 2014 | 03:00 PM
Just heard back from Nissan regarding this issue... apparently there are 2 plugs behind the radio that will fit 2 spots and I had them reversed. I figured since everything had a home this wasn't possible because who would make 2 identical plugs in the same area? Nissan...
edit: $406 for the Nissan dealer to switch 2 plugs. Ridiculous. Hopefully this helps someone else out.
Old Sep 10, 2014 | 05:05 PM
jervaise's Avatar
What year is your max? I'm having display issues with my '06
MattWithTheMaxima
Jun 30, 2017 01:06 PM
dr3am
25
Oct 22, 2015 08:53 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
Max8
Aug 20, 2015 07:20 PM
kenc15
Aug 5, 2015 08:29 AM
