replacing tensioner 04 max
Old May 27, 2012 | 09:35 AM
ivan76k's Avatar
can anyone help im having problem putting the engine on my 04 max in timing after changing the tensioner on the cam cam chainr
Old May 28, 2012 | 05:34 PM
L36's Avatar
L36
You need to be more specific.
Old May 28, 2012 | 07:41 PM
esco115's Avatar
Let me help, he pulled his motor out to replace stuff on it... timing chain guides, sensors, tensioners, etc...
Well now he is having trouble getting it back to timing, meaning lining up the cams with the crank.
Old May 28, 2012 | 08:04 PM
NismoAce's Avatar
Engine is still out of the car?
Old May 28, 2012 | 08:31 PM
L36's Avatar
L36
Take off the valve covers, you will see that the camshafts have a slot where you can insert the wrench and turn them. First, put on the secondary chain, the small ones on each bank so you turn both intake and exhaust cam at the same time. Follow the markings on the sprockets to get the time right, or you'll bend valves. The big sprocket should have a dot on the side where the smaller chain goes, that's the mark. The exhaust sprocket should have 2 markings on it by the teeth. The chain should have one link colored on one end and another end 2 links colored.
Line up the small chain with those markings and links, take out the pin out of the tensioner. Then, bank is ready to be adjusted.
Make sure cylinder 1 is set to TDC.
Old Jun 2, 2012 | 03:32 PM
ivan76k's Avatar
yes nismoace engine out the car (im having problem with the crank is not spinning all the the way around even wen i have the valves in line
Old Jun 3, 2012 | 02:52 PM
L36's Avatar
L36
Have yo taken out the sparkplugs? It might be just compression, unless you feel like hitting something.
Old Aug 23, 2012 | 06:34 AM
bris04max's Avatar
I am curious if the cam shaft sprockets go bad due to age?
I guess, if I replace the tensioner should I replace the cam sprockets, crank sprocket and timing chain? The cam sprockets cost more than everything else combined.
Any thoughts would be great!
Old Aug 23, 2012 | 07:08 AM
mrjasonlyrics's Avatar
I'm sorry man but this thread is confusing as hell. So you're saying you pulled out your engine to change tensioner and what not but you don't know how to do the timingdid you watch a youtube video or something
CRizz
41
Jun 7, 2021 05:42 AM
HOKUSMAX
Nov 13, 2017 04:34 AM
erictown
Aug 20, 2015 08:01 AM
YourLocalAsian
Aug 17, 2015 02:33 PM
jholley
Aug 11, 2015 09:38 AM
