Wheel hub and bearing
Old Sep 6, 2012 | 01:33 PM
Allisinthepass's Avatar
So turns out that the noise that my maxima was making was a crooked wheel hub and needs replacement. Anybody know of a good website to get the front wheel hub + bearing. I have been around a few, but does anybody have any good recommendations (would be a bonus if it was in Canada).
Old Sep 11, 2012 | 12:23 PM
CanadianMoFo's Avatar
I got a wheel hub and bearing set from a dude on eBay. Was cheaper than any other way even though it was shipped out of the US. The OEM ones are staggeringly expensive.
CM
Old Sep 11, 2012 | 12:24 PM
Complete rear wheel hubs are available through www.primechoiceautoparts.ca for about $50 each.
Old Sep 11, 2012 | 12:36 PM
CRiME's Avatar
oem ftw!
Bought my front hubs/bearings from an eBay seller as well. Installed with no issues, noise gone, never came back.
http://www.ebay.com/itm/Nissan-Maxim...ht_2058wt_1154
Old Sep 13, 2012 | 03:47 PM
Kryogen's Avatar
what noise were you having?
seems like I head a bearing sound my my car also.
front or rear?
Old Sep 13, 2012 | 05:25 PM
CRiME's Avatar
oem ftw!
front or rear?
I changed the rear (both sides) to fix my ABS problems. I changed the front (both sides again) because I began having a noise that almost sounded like a motorbike or a civic with a coffee can exhaust (though obviously not as loud). I could probably also describe the noise as a bicycle being driven with a card in the spokes - something along those lines. The noise would increase in pitch as the vehicle's speed increased. Over time the noise began to get worse. The noise would go away when I turned hard to the left while going at moderate speed, which was characteristic of a bad d/side wheel bearing.
I got new bearings and hubs for both sides - figured may as well replace the p/side while I'm at it. Noise went away and car handled much better as well. Driver's side bearing was completely shot.
Old Sep 13, 2012 | 05:54 PM
7speed's Avatar
Might also want to pm Aackshun, he is a member on here that works with Nissan parts out of Houston. He may be able to get you a deal.
Old Sep 14, 2012 | 08:04 AM
Just saw that www.autopartsway.ca has the hub and bearing available. I order parts there all the time, never had a problem.
CM
Old Sep 15, 2012 | 08:10 PM
Longhorn101's Avatar
Are there special tools required for the fronts? I thought i read a press was required for the bearing?
Old Sep 17, 2012 | 12:50 PM
CM
thanks ima get them from there
James92SE
142
Jan 2, 2024 09:23 AM
londonflu
40
Sep 25, 2015 09:11 AM
Bonka
Sep 14, 2015 11:18 PM
jfl330
Sep 4, 2015 01:44 PM
maximusrising
Sep 2, 2015 09:55 AM
