Door lock actuator
Old Sep 13, 2012 | 11:47 AM
SmaX's Avatar
Door lock actuator
So my rear passenger door lock actuator suddenly got very weak. It will still open and close but it seems as if it has very little power. Also, I can hear that it sounds different from the other ones. Sounds broken. I've read that this is pretty common for Nissan's. I can get a new one for $60 from the dealership but I was wondering if there is anything I can do to repair the old one? It's the rear so it's not as a big deal as the front would be. But still annoying. Any help appreciated.
Old Sep 13, 2012 | 12:29 PM
CanadianMoFo's Avatar
No they are all pretty well sealed. There's pretty much no way to clean them out. They're not serviceable at all. When mine started going I replaced them myself and had a good look at them. Better off just buying them and replacing them yourself. Took about 2 hours for the first one, and once I knew what i was doing it was way shorter than that. The rear doors don't have the metal plate in front of all the workings and are easier to get into than the front doors so you're in luck.
CM
Old Sep 13, 2012 | 03:46 PM
Kryogen's Avatar
60$, good deal, close to 200 here
Old Sep 13, 2012 | 10:55 PM
SmaX's Avatar
CM
Thanks, I just don't know how to get that one wire out from the door handle, is it easier to remove the handle?
Only because a buddy of mine works at the dealership, regular was $120. Still cheaper
Old Sep 16, 2012 | 09:20 AM
I can't remember the exact steps, but yes the entire door handle gets removed in the process.
Old Sep 16, 2012 | 09:23 AM
Try this,
http://forums.maxima.org/7722060-post14.html
Old Sep 16, 2012 | 09:26 AM
Actually this thread shows really well how to remove the door panels, handle and actuator. I used it when I was first taking apart my doors.
http://forums.maxima.org/6th-generat...d-install.html
Old Sep 16, 2012 | 04:54 PM
CRiME's Avatar
oem ftw!
^^ Excellent post.
Thanks for posting that. Will be very helpful when I change my actuators.
REDinLV
Aug 15, 2024 12:30 AM
magiconthetire
Oct 26, 2015 09:03 PM
BobTX10
Oct 7, 2015 08:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Andy29
Sep 29, 2015 05:32 AM
