vibration issue
Old Oct 26, 2012 | 04:08 PM
fng21222's Avatar
vibration issue
The problem I'm having is a vibration in the gas pedal when accelerating. It only happens under 2000 rpms and that's it . Has anyone had this problem ? Thanks for any help or pointing me in the right direction .
Old Oct 26, 2012 | 04:32 PM
L36's Avatar
L36
I have that too, i never bothered figuring out whats the deal.
Old Oct 26, 2012 | 04:38 PM
mrjasonlyrics's Avatar
Maybe it's just vibration from a bent rim that gets transferred to the pedal or your front end suspension. Or your rotors are worn or on incorrectly. Try taking off the wheel and shake your control arm, outter tie rod and brake assembly. Maybe if you're lucky you'll get a free play
Old Oct 26, 2012 | 04:39 PM
L36's Avatar
L36
Can also be a bad wheel bearing.
Old Oct 26, 2012 | 04:45 PM
po8pimp's Avatar
can also be bad brake pads, transmission, loose pedal, engine vibration from bad motor mounts, exhaust vibration, pretty much anything loose, engine gnomes, etc.
Old Oct 26, 2012 | 04:51 PM
fng21222's Avatar
Thanks for all the inputs , I'll check the control arms first since when i hit the gas i hear a creaking noise.
Old Nov 1, 2012 | 04:25 PM
fng21222's Avatar
forgot to mention that the vibration i feel in the gas pedal as well as the steering wheel slightly. also this happens no matter what speed i'm going as long as the rpms are between 1500-2000 but goes away after 2000 rpms. could it be the motor mounts are going bad? i don't feel them moving when i accelerate hard.
Mar 12, 2020 12:06 AM
02PearlSE
Feb 1, 2016 12:37 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
Bonka
Sep 14, 2015 11:18 PM
thenewguyy
Sep 12, 2015 11:12 AM
