Maxima is starting all by itself!
Old Nov 1, 2012 | 05:07 PM
Hj2of4's Avatar
My 2008 Maxima engine has started by itself 3 times in the last 10 days. I took it in to the dealer but they could not duplicate the problem. Has anyone else had this issue? The first time I considered that I may have been scatterbrained but the other two times I am positive that I turned off the engine. My car has the keyless start and if I walk away from the car with the key and the engine is on it will beep at me. The car did not beep so I know that the engine was off, yet when I have returned my car is locked but running.
Old Nov 1, 2012 | 05:54 PM
po8pimp's Avatar
you might be accidentally pushing the remote start. I recommend looking more at the key-fob sticking.
Old Nov 1, 2012 | 06:40 PM
turbo_max's Avatar
What about a short on you push start switch ?
Old Nov 8, 2012 | 05:47 PM
nsnrider's Avatar
you have to be close to the car for the push button to work.
I would look at the remote.
Old Dec 15, 2012 | 01:35 AM
maxdowt's Avatar
Not to mention you have to press the brake. You might not even have a short in the switch, you could simply be sitting on your keys the wrong way.
Old Dec 15, 2012 | 09:50 AM
04BlackMaxx's Avatar
Its alive!
Old Dec 20, 2012 | 10:05 PM
pitmax31's Avatar
Is your car named Christine?
Old Dec 21, 2012 | 11:24 PM
DAlastDON's Avatar
Old Dec 23, 2012 | 12:36 PM
dougb's Avatar
Can the remote start be set to turn the car on intermittently? I had an aftermarket remote starter that had this ability. One night I thought I heard the engine start, but didn't check. Then a couple of nights later I saw the parking lights flashing, indicating the car was running. I then read the manual for the starter and realized there was a key sequence that would set it in a mode to start every 24 hrs.
kjlouis
Nov 24, 2018 06:09 AM
02PearlSE
Oct 7, 2015 02:12 AM
acw
Aug 13, 2015 12:50 AM
halfpol
Aug 5, 2015 08:24 PM
Jcof88
Aug 3, 2015 10:43 PM
