2004 Maxima SE ABS issues
Old Jan 30, 2013 | 04:43 AM
kennymontee's Avatar
i have been experiencing issues with my abs where the abs kicks in on speeds 0-10mph and the vdc off, abs and slip lights are all on.I have taken the car to a nissan dealership where my cam shaft sensors,rear abs sensors where all changed but the problem still persists.The nissan dealership said that i should replace the abs actuator, i wanna know your opinions on whether i should disable the abs for now till i fix the actuator.I live in toronto ontario and we have alot of snow in the winter and i wanna know how safe is it to drive without abs in the winter. I understand that the abs is a secondary bvraking system to the regular brakes
I also want to know what switch to pull in order to disable the abs.
Old Jan 30, 2013 | 04:52 AM
CRiME's Avatar
oem ftw!
It might not be your actuator. Bunch of people (myself included) have battled this problem. I fixed mine by replacing both of the rear wheel hubs. ABS has been working properly for over a year now. The problem is that there is a design flaw which allows rust, corrosion, dust and dirt to build up inside of the hub which sends a bad reading to the ABS sensors. This causes the ABS to engage when it shouldn't. This problem is magnified in areas that see a lot of snow and road salt. Nissan released a TSB in which you can clean out the hub yourself, and grind out a notch that will allow water to drain properly. The TSB is here:
http://ww2.justanswer.com/uploads/ba...NTB07-016b.pdf
But for the record, I drove my car for about a year with the ABS disabled before I finally found some time to fix it once and for all. I disabled it by unplugging the front passenger side ABS sensor (easily disconnected via the harness near the coolant reservoir).
Old Feb 3, 2013 | 07:59 AM
04BlackMaxx's Avatar
Start saving your money, numerous threads on this.
Old Feb 3, 2013 | 08:57 AM
gatsugansu's Avatar
Just curious, when you unplug the ABS sensor does your speedometer still work?
Old Feb 3, 2013 | 10:10 AM
CRiME's Avatar
oem ftw!
Yep, speedo was unaffected which seems not to be the case when the ABS CONT fuse is pulled instead. Only thing that changed was that disconnecting the sensor disabled the ABS.
Old Feb 21, 2013 | 08:44 AM
TDKDF's Avatar
Thanks for the post. I was able to do this until I can get my car fixed.
Old Feb 23, 2013 | 01:09 PM
CRiME's Avatar
oem ftw!
No problem man, that's what this place is all about. Glad it was able to help you out.
Old Feb 24, 2013 | 02:04 PM
Thanks for the input man so do you know where i can get a diagram that shows me the location of the abs sensor on the passenger side.Also how were your brakes and overall braking with the abs disabled
Old Feb 26, 2013 | 06:18 AM
TDKDF's Avatar
For anyone that has done the TSB but it didn't solve the issue, what did you end up having to replace?
ah2002
Mar 9, 2016 01:42 PM
Finkle
Sep 27, 2015 09:53 PM
soon2ownmax
Aug 13, 2015 02:19 PM
acw
Aug 13, 2015 12:50 AM
