Can you reset abs codes without the machine?
Old Feb 11, 2013 | 07:03 PM
Kryogen's Avatar
VDC and brake light are on. Last time I went to nissan they got a code for low brake fluid (it is not low) They did a reset and I was good for 3 months.
Code is on again. I don't have an abs code reader.
Any way to reset abs codes without going to dealership? A bit annoying because my abs and VDC are off and it's winter time, and icy.
Old Feb 12, 2013 | 10:35 AM
NmexMAX's Avatar
dot dot dot ...
Find someone with a Cipher, from UpRev.
But if you have a bad ABS sensor, you'll need to change it before the lights go out, and VDC is back.
Never seen a code for low brake fluid. My "code" for low brake fluid is the "Brake" light on.
Old Feb 13, 2013 | 04:12 AM
Kryogen's Avatar
I will try disconnecting the neg battery terminal and see if it clears the code.
if it comes back on, then go to nissan I guess.
Old Feb 17, 2013 | 02:42 PM
Kryogen's Avatar
brake fluid was really in fact low, fail on nissan.
I have a leak somewhere. refilled, code is gone.
Old Feb 17, 2013 | 05:37 PM
nsnrider's Avatar
you can do the paper clip trick using the obd connector.
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
leatherneck
Sep 30, 2015 09:16 PM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
