Paint touch-up help
Old Mar 6, 2013 | 02:50 PM
chrismax11's Avatar
Paint touch-up help
I have a 06 maxima that is sheer silver mist or KY-1. I am trying to put the pic of the spot on here but no dice. Can I sand and clean and base coat. Then clear coat twice. Would it make a difference. Any advice is appreciated.
Old Mar 6, 2013 | 02:58 PM
chrismax11's Avatar
I am going to try anyway. It can't look any worse. Ill try a little base coat on my old factory rims first and then go from there.
Old Mar 6, 2013 | 03:13 PM
chrismax11's Avatar
I can go to ppg and have them mix some paint up to match so one way or another i will eventually fix it.
Old Mar 6, 2013 | 03:54 PM
mrjasonlyrics's Avatar
Dude what the fudge did you do to your bumper? You shouldn't try to spray paint an entire bumper for any reasons. A blind man could see the difference in the dark. When you attempt to half paint any car with can spray you will always get two shades, and there's no way to get away from that. My advice to you is to have it painted professionally so that they could atleast try to match it with your already faded paint. If it's a small part like a gas flap or something you can paint the entire part then you can take a chance but a bumper is a definite no no. An average paint shop should charge about $150-250 on an OEM bumper that just needs to be repainted with no extra work.
Old Mar 6, 2013 | 04:55 PM
chrismax11's Avatar
I wasnt trying to paint the whole bumper. I didnt do a big enough area and when i took it off it left the outline.
The paint i got was from advance auto. Big mistake. What happened was a woman did not know what the white lights on the rear of the vehicle were for.
I
Old Mar 6, 2013 | 04:57 PM
chrismax11's Avatar
I
I got quoted 400 because they want to paint the whole thing.
Old Mar 6, 2013 | 05:51 PM
lobewiper's Avatar
It depends on the quality of work you want. For a pretty good job, 200 will get it done pretty well by the guys who do touch up and remove small dents paintlessly for your dealer's used car dept. If you want a like-new job, the bumper cover will have to be removed and replaced after it's painted, which is probably why you were quoted 400. In Chicago, 5 to 600 would be charged by many body shops, but if you shop around you could find one that would do it for 400. Depends also on the area to be painted. The shops that mix the original paint can't take into account fading, so you might need to paint a larger area than the actual spot for purposes of blending. My experience is, anybody can paint using a spray can, but few can paint well enough to just do a spot unless they know what they're doing and use a buffer to smooth and blend the final coat. Painting well usually takes a good deal of experience. Let the guy that does the used car touch up spray the whole thing without removing the bumper cover for about 200 and spend your time on less tedious and frustrating repairs, unless you're content with an average job. (You can use a buffing pad on an electric drill to apply rubbing compound, or even do it by hand.) If you do decide to do it yourself, post up before and after pics, please.
Old Mar 7, 2013 | 10:10 AM
$400, I won't even pay that to do my bodykit bumper and it's way bigger. Keep looking uuntil you can find some in the $200-300 range
REDinLV
Aug 15, 2024 12:30 AM
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
doctorpullit
Apr 23, 2017 05:35 AM
Luigi623
Sep 21, 2015 01:42 PM
