coolant leak cant tell were its coming from
Just replaced my radiator on my 04 maxima but before, I flushed out the system with the old radiator in before installing the new one everything went good till I woke up the next morning with a big puddle under my car got under and seen that it is dripping from the front and rear of my oil pan but I cannot find were its coming from. The car was fine before with no leaks except from the top of the radiator so I'm thinking if flushing out the system might have caused it any suggestions or any one that might have had a similar problem?
Are you sure its dripping directly from the oil pan? Liquids are tough, because they find the path of least resistance. I would wipe everything up real good with a couple rags, make sure everything is good and dry and then go over every hose and hook up to see where it is coming from...
MR2 T'd
07-09-2021 05:06 AM
trungg86
09-04-2015 04:58 AM
