Problem after replacing window regulator/motor
Old Aug 3, 2013 | 05:47 PM
MaximaJames's Avatar
Hey everyone. I have a 2004 Nissan maxima and just replaced the window regulator and motor in the front drivers side door. Everything came apart and went back together fairly easy and the window works perfect. However now my front door power locks aren't working right.
The doors lock/unlock from the outside with the key just fine. But if I sit in the car and press the power lock only the rear doors lock and unlock correctly. I'm at my wits end here so any suggestions or ideas will be helpful. If you need any more info let me know. Thanks ahead of time
Old Aug 3, 2013 | 11:15 PM
po8pimp's Avatar
check that you plugged all of them in correctly and in the right spots. I think one of the plugs fits two of the plug outlets. I would also check the fuses to make sure when you plugged and unplugged that you didn't blow one. More than likely it is the plug.
Old Aug 4, 2013 | 04:16 PM
Kryogen's Avatar
some connection somewhere
Old Aug 4, 2013 | 04:49 PM
With the door taken apart the cable responds to the locks. It comes in/out when I hit the lock button. But when I hook it back up and try it it doesn't work for some strange reason
fastcarny
May 18, 2020 10:40 AM
vingodine
45
May 21, 2016 12:46 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
doctorpullit
Aug 20, 2015 05:15 PM
kirkhilles
Aug 8, 2015 10:53 AM
