2005 maxima slip light
Old Sep 20, 2013 | 06:36 PM
weston22s's Avatar
ive read lots of post about slip lights abs light ses lights with a bunch of other problems here is mine.
2005 maxima 107k miles as soon as you take off and go over 10 mph the slip light flashes and power is cut from traction control activating this is the only problem with the car if you turn tcs button off drives perfect ok here are the codes that were scanned
abs- c1130 engine signal 1
c1103 fr rh sensor 1
po codes
po882 tcm power input signal
po500 vehicle speed sensor a
po726 engine speed
car has had the front rt speed sensor replaced changed nothing,no coins in the ac amp thing under radio screen the brake fluid is fine took the rear abs sensors out looked good cleaned the sensors and the rear hub reading ring. replaced a corroded looking battery ground wire changed nothing also 14 volts from alternator with loads on these are the things i read to check so i did any other input would be much appreciated.
Lakersallday24
Nov 7, 2024 07:31 PM
Lakersallday24
Jun 16, 2019 01:35 AM
SmokinMax02
18
Sep 11, 2015 12:25 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
cmpowell86
Aug 10, 2015 12:35 AM
