Squeaking Noise at 2000 rpm
Old Sep 29, 2013 | 12:27 PM
steelerfan3936's Avatar
Hey guys. I have a 2007 Maxima and I have developed a strange problem. Sometimes, not always, when my car reaches 2000 rpm, it makes a sqeaking noise from under the car. (it sounds like somewhere in the left front) The noise goes away when it gets past 2500 rpm. If I try to rev the motor in park, I can not recreate the sound, it only happens while driving. Any ideas on what this could be???
Old Sep 29, 2013 | 12:33 PM
MAXMEL44's Avatar
I'm getting the same noise. I've had it for over a year now.. I have no idea what it is. The dealer couldn't find the noise either
Old Sep 29, 2013 | 02:54 PM
po8pimp's Avatar
get some spray lubricant that is made for belts, spray the belts, then get some all purpose lubricate used for gears, and spray the gears. this should eliminate your noise. If it doesn't, at least your belts and gears are cleaned and conditioned.
Old May 17, 2015 | 07:26 PM
johnnahvi's Avatar
Maxim squeaky noise around 2000 RPM
I have a 2001 Maxima GLE. My car when reaches 2000 rpm, it makes a squeaking noise from under the car. (it sounds like somewhere in the left front). We found the noise to be under the car under the driver seat area. The noise was a broken ground wire that comes off the catalytic converter and connects to the chassis of the car which just happens to be around the under side of the car in the driver seat area. The broken wire resonated around the 2000 RPM. I removed the ground wire and no more noise around 2000 RPM. I did not replace the ground wire because the exhaust pipe to me is a ground by connecting to the engine block through the multiple exhaust pipes and bolts making connections between the pipe segments.
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
Unclejunebug
Apr 2, 2016 05:42 AM
Need help
23
Oct 2, 2015 08:56 AM
Andy29
Sep 29, 2015 05:32 AM
