2004 Maxima SE power seat problem
Old Nov 18, 2013 | 07:11 AM
jokers1995's Avatar
Ok, so I just bought my 2004 Maxima SE on Sat. morning. After signing all the paper work and everything, I realized that the driver side power seat does not work and the power steering wheel tilt does not work either. Anyone have any ideas about how to fix this? Is this a typical problem Please help!
Old Nov 18, 2013 | 03:12 PM
Lovemycar's Avatar
have you checked the fuse? does it move manually or is it the driver seat pre set
Old Nov 19, 2013 | 12:24 PM
jokers1995's Avatar
The seat is ALL power. Doesn't move manually at all. All fuses are good (i believe). Is there just the one fuse box on the driver side and under the hood? If so, they are all good.The passenger side works, just not the driver. But the steering wheel tilt doesn't work either.
Old Nov 19, 2013 | 02:22 PM
CALIMAX06's Avatar
You might want to check the harness under the driver's seat and make sure none of the wires are damaged. If one of these wires is pinched it can cause the symptoms you're describing.
Old Nov 20, 2013 | 12:02 PM
jokers1995's Avatar
i did. all fuses are fine. wire harness is fine. idk what to do.
Old Nov 20, 2013 | 12:13 PM
Lovemycar's Avatar
Take it back to where you bought the car dude that's what I would do have tdo
Old Nov 20, 2013 | 10:14 PM
po8pimp's Avatar
The power seat I believe is a recall item, might get it repaired for free. The tilt for the wheel is mechanical and has absolutely nothing to do with the other. I would suggest playing with it, it could be stuck.
Old Nov 20, 2013 | 11:30 PM
CALIMAX06's Avatar
Actually, the steering wheel, door mirrors, driver seat, and I believe the pedal as well are all connected by the auto drive position control system. If one those wires comes loose or gets damaged it can cause both the seat and the steering column not to function properly. It happened to a buddy of mine.
Old Nov 21, 2013 | 06:47 PM
po8pimp's Avatar
yeah my bad, I didn't give the best of advice on this. I don't have the memory seat function. I have power seats, just not the 1/2 push button for memorizing seat position and what not. My tilt wheel is done manually not electronically.
Old Nov 23, 2013 | 09:24 AM
jokers1995's Avatar
I called the place I bought it from, they said I would have to pay for it and they wont cover it!!! And yes, I read that the power steering tilt and seat are tied together. But I cant find anything wrong with the wiring. I'm giving up until I have money to have it checked out.
Old Nov 25, 2013 | 12:37 PM
Lovemycar's Avatar
was the car bought as is if not are you still within the 30/60 warranty then they should fix it that's bull ****
Old Dec 1, 2013 | 07:30 AM
jokers1995's Avatar
I bought it as is. They also sold the car to me with a nail in the tire and it wasnt repairable. I saw it was a little low but not really that much lower. But a couple days later it was completely flat and I had to get a new tire.
Old Dec 16, 2013 | 12:33 PM
jokers1995's Avatar
Anyone able to help me on this? Problem is still going on. All the fuses are fine and so are the wires. My power mirrors still work. Only my driver power seat and my power steering tilt do not work! I need help!
Old Dec 16, 2013 | 03:30 PM
CALIMAX06's Avatar
Ok so fuses are good, harness is good, and it sounds like the auto position control unit is getting power since the sideview mirrors are still working. Im thinking the unit itself is bad but I would recommend taking it to Nissan for a proper diagnosis.
Old Dec 17, 2013 | 02:34 PM
jokers1995's Avatar
OK thanks! I can get that part for about 35 dollars so I might just buy the part. The closest Nissan dealer is over 40 miles. So if it isn't the part, then Ill return it and go to the dealer.
Old Apr 1, 2014 | 02:08 PM
mrkhone's Avatar
did u fix the problem yet. i'm having issues with mine. my steering wheel won't tilt anymore. it happened after i installed my double din. everything else works fine besides taht.
Old Apr 24, 2014 | 01:29 PM
steinjr's Avatar
I also now have this problem! Any solutions?
Old Apr 24, 2014 | 01:52 PM
Slick_1222's Avatar
I had the same thing happen to mine. I took out the drivers seat, played with the wires. I connected everything back as it was and boom, works like a charm.
Old Apr 24, 2014 | 01:56 PM
steinjr's Avatar
Thanks for the info. Was there any obvious issue?
Old Apr 24, 2014 | 02:08 PM
Slick_1222's Avatar
That I remember no, I played with the wires because I read a thread in here about it. If I remember correctly the wire harness is a recall.
Old Apr 26, 2014 | 11:04 AM
04BlackMaxx's Avatar
Yes they rerouted mine after service one time many years ago and the seat pinched the wire and killed it.
Old Apr 26, 2014 | 12:36 PM
steinjr's Avatar
I didn't have time to pull the seat, but I did reach up under the seat to feel around for any loose or pinched wires. Didn't feel anything obvious, but the seats and steering wheel are working now.
I called Nissan about recall #49984 and they said it's only for the lumbar portion of the seat and has nothing to do with the wiring harness getting pinched.
Old Apr 28, 2014 | 01:10 PM
My lumbar broke 2x on the car and I didn't even bother fixing it the third time as I figured it would just break again because of poor engineering. The pinch problem was the entire back portion of the seat and that never reoccurred once fixed. Little things like thisreally annoyed me because there were so many little things that added up.
Finkle
Sep 27, 2015 09:53 PM
Gsantos79
Aug 8, 2015 07:41 AM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
