2005 Nissan Maxima SL Jerking
Old Dec 24, 2013 | 06:34 AM
Farouq11's Avatar
I have a 2005 Nissan Maxima SL that Jerks whenever going from park to reverse and from park to drive. Manual shifting is very smooth though. I have also installed 4 brand new motor mounts and had a transmission flush but that still doesn't seem to solve the problem. Someone please help! Thank you.
Old Dec 24, 2013 | 07:25 AM
njmaxseltd's Avatar
Are you parking on a hill? If so, set the parking brake before putting the vehicle into park.
Old Dec 24, 2013 | 07:36 AM
D.Stillwell's Avatar
Sounds like motor mounts (I see you replaced 4 of them), unless indeed you are parking on a hill.
Did the jerking happen before you replaced those mounts or did it start after? Why did you replace 4 mounts, were they all bad?
Old Dec 24, 2013 | 07:56 AM
Farouq11's Avatar
Yes I do park on hill with the parking brake too at my house, and the old motor mounts were all going bad so it was necessary for me to replace them. Even though I did, it still jerks whenever I go from park to reverse, or from park to drive. And that happens whenever I am not on a hill.
Old Dec 24, 2013 | 07:58 AM
Farouq11's Avatar
the car jerks when I put it in drive and reverse.
Old Dec 24, 2013 | 11:17 AM
CRiME's Avatar
oem ftw!
Sounds like your valve body is failing. Any trouble codes? Check out the transmission fix thread.
http://forums.maxima.org/6th-generat...ssion-fix.html
Old Jan 7, 2014 | 11:20 AM
04BlackMaxx's Avatar
I thought by the title the design of the 2005SL has you majorly turned on.
Old Apr 3, 2014 | 09:16 AM
kfrants14's Avatar
codes
The vias control solenoid valve could be acting up, my nissan had the same problem and that did the trick for me
xUNIxPanther
Aug 27, 2015 10:09 PM
District
Aug 15, 2015 08:23 PM
niZ
Aug 7, 2015 10:18 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
