Right Rear ABS Sensor C1105
Old Apr 2, 2014 | 05:17 AM
denis_the_thief's Avatar
Anyone familiar with Right Rear ABS Sensor C1105?
I know thee is a service bulletin but I didn't undersand the need for that notch or what the plastic hub was for.
My mechanic replaced the Rear Right ABS Sensor but the ABS still does not function - gets C1105.
Does that mean it is the part was bad or could be? Should I try cleaning behind the sensor or wash it out (i.e. pull out the sensor and spray in that hole). Is there a way we can determine if it is the sensor or something else?
Old Apr 2, 2014 | 09:51 AM
Samvqftw's Avatar
Been looking for the same answer myself. I have the exact problem & did the same procedure as you. But abs light still there!! :/
Old Apr 2, 2014 | 10:58 AM
Thanks. Did you do the whole thing on the service advisory or just changed the sensor. So far, I have only changed the sensor.
Old Apr 2, 2014 | 10:00 PM
Samvqftw's Avatar
Just the sensor. Im going to try to clean the hub n see if there's a bunch of dirt & stuff accumulated. Hope that helps.
Old Apr 3, 2014 | 07:44 AM
LiquidEliteMax's Avatar
hey guys, I have a similiar problem. I changed my abs actuator because my rear left abs sensor ate it up and and after that i replaced the abs sensor with a oem one and the brake light is still on...it's driving me crazy. I don't know what to do next.
Old May 6, 2014 | 04:51 AM
I'm still stuck on this. Car is back in the shop. Mechanic thinks it is the wire going to the sensor, maybe a problem under the seat.
Does anyone know if disconecting the entire line, i.e. under the hood, I think that is the harness, if that would work? Or what would happen? The thing is if I am sliding on ice, I don't see how only reading 3 tires (instead of all 4) would be an issue.
Old May 6, 2014 | 07:05 AM
Matt42687's Avatar
I had the Brake Light come on and went through the system and found nothing. I cleaned all the abs sensors and the light went off. The person who had the car before me put some cheap pads on which causes ALOT of brake dust. I think that was the problem on why they all got so dirty. From what I have gathered if the abs system is only reading 3 wheels it will throw a Brake light or ABS light. hope this helps
AnsonJ
Jun 2, 2017 01:35 PM
Huttig2009
Sep 25, 2015 03:31 PM
VerzOphion
Aug 28, 2015 07:57 PM
2k0to2k3
Aug 18, 2015 09:59 AM
