04 door locks. Help if you can please
Old May 23, 2014 | 07:26 AM
Nuclearninja's Avatar
Some of my locks don't work at all, some work sometimes. I have been reading and it seams that it is either the actuators or the BCM. I'm probably just going to replace the actuator on one first to see if that helps. There is one thing I find odd. The driver side rear always works but after I cycle it a few times it slows down and finally quits. Kinda like it is running out of power. If I wait a few minutes and do it again, it works fine for a few more cycles. Does that ring a bell with anyone that might have a suggestion as to which way to go? I hate to go to dealership. Especially since it is an hour away.
Old May 23, 2014 | 08:12 AM
CRiME's Avatar
oem ftw!
Yeah, that is characteristic of a door lock actuator problem. Mine went bad on the passenger side F & R at the same time. Noticed it on a hot day when the car was parked in the sun. Locks would struggle, and if I were to cycle it as you did, it would eventually reduce to nothing, not even a twitch.
Old May 23, 2014 | 08:48 AM
Thanks pal. I needed some confirmation.
Old May 23, 2014 | 06:08 PM
CRiME's Avatar
oem ftw!
No problem. If you're going to tackle it yourself, this writeup for the door handle LED install may be helpful as far as taking the door apart to access the part.
http://forums.maxima.org/6th-generat...d-install.html
Old May 23, 2014 | 06:25 PM
Goomz's Avatar
have you had aftermarket speakers installed? i've seen the cable that controls the lock/unlock motor not reinstalled correctly and that can cause the locks not to move all of the way, but if you say the rears also are acting up then it may seem that this is NOT the issue, being that the rears are on the deck, not the door. but if not, then yeah sounds like a classic actuator dying tale.
REDinLV
Aug 15, 2024 12:30 AM
trsandrew
Apr 8, 2016 06:45 PM
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
BobTX10
Oct 7, 2015 08:43 AM
