trans fluid
Old Jun 15, 2014 | 06:12 PM
blakedanatural's Avatar
trans fluid
Hello All,
I 've been having issues with camshaft sensors etc.. as I have posted in the last several weeks. My transmission was the issue with all the fault codes. I was leaking fluid badly ,wouldn't shift right . I got 198400 miles out of the original trans. I got a used one from a salvage spot with 98000 miles on. I took it to my mechanic and I went to Nissan and purchased 6 quarts of k_ matic transmission fluid.
When I came to pick up my car he handed me the fluid I purchased and said he had fluid already. I get home and look at my invoice and it says synthetic transmission fluid 6 qts. I drove a couple of days and it appeared ok but now its shifting funny. I know its a used transmission but my question to you guys is, can I flush this fluid it out and have the K matic put in. Hopefully it will shift smoother. What do you guys think?
Blake
Old Jun 15, 2014 | 09:38 PM
CRiME's Avatar
oem ftw!
Don't do anything, take the car back to the shop ASAP. You paid for a job and your car is not running properly. There is a good chance the valve body in the used transmission is failing as well. It's such a common issue with these cars. If you flush out the fluid and he figures it out, they will try to avoid any warranty work on the transmission job. I battled this issue for a couple of years with my car.
Old Jun 16, 2014 | 03:35 PM
trans fluid
Gotcha ! Do I tell him to replace the fluid with K Matic Fluid cause its not shifting clean in the earlier gears?
Old Jun 16, 2014 | 06:52 PM
CRiME's Avatar
oem ftw!
You can if you like, but I would have him check the valve body if you are experiencing those symptoms, and go from there. Would be a shame for them to put in your K-matic and then it turns out the valve body or something else is wrong in the used transmission.
Old Jun 17, 2014 | 02:01 PM
trans fluid
Ok he told me to bring it in Thursday. I will let you know what happens. Thank you for your comments! And he owes me money for a replaced camshaft sensor bank 1 .I told him I installed one already but forgot to erase the code. He used obII and found P0340 and replaced. THe stealerships are the only guys trying to steal from us. LOl
Old Jun 17, 2014 | 02:55 PM
CRiME's Avatar
oem ftw!
Dang. No problem. Good luck man, I hope everything works out for you.
Old Jun 17, 2014 | 07:06 PM
Kryogen's Avatar
go back and have him make it work.
he did not use the proper fluid.
k matic only for this tranny.
dont touch anything.
Old Jul 13, 2014 | 01:33 PM
Trans Fluid
Thank you all for your responses and help. Yes I took it back and he changed the fluid to Nissan Kmatic. The car has been running much better since the change. The used trans had 95000 miles on it when installed. My original one went bad at 199000 miles on it. It was the original trans too. Im hoping this used one can give me another couple of years.
Blakedanatural
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
hayne
Oct 5, 2015 11:53 AM
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
