2006 nissan max after rostra solenoid replace
Old Sep 14, 2014 | 04:47 PM
DrobMax's Avatar
Okay I replaced my 2006 nissan maxima with the rostra solenoids. I attempted the relearn procedure but the same problems still exists. So I tried a road test that consisted of 60 miles and it drove the highway no problem staying in 5th gear coasting. Once I came to a red light the maxima hesitated to move after coming to a stop position. Also when I try to reverse the motor just revs to about 4k rpm and trys to move but acts like it's skipping. Then when place in drive the same problem. Any suggestions
Old Sep 28, 2014 | 05:29 AM
Khamisalminawi's Avatar
Usually means from my experiance that the internal gears/pump inside tranny are worn and when it gets hot the fluid thins out. If its good when cold you should consider adding an extra tranny fluid cooler by radiator
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
SmokinMax02
18
Sep 11, 2015 12:25 AM
doobadoo
Aug 15, 2015 06:43 PM
follyburr
Aug 12, 2015 08:57 PM
