opinions needed
Old Nov 11, 2014 | 06:34 AM
Supergupp99's Avatar
opinions needed
So we are gunna do the engine install/replace this weekend on the 04 Max, anyone know any lil hidden things i can or should do to better the performance or life of the new engine?
Old Nov 11, 2014 | 06:45 AM
D.Stillwell's Avatar
^^ I'm not a 6th gen expert, but I do know these things...
Most would recommend doing timing chain tensioners, pcv oil catch can, and doing a valve body upgrade so the tranny lasts.
Old Nov 11, 2014 | 07:38 AM
^^ I'm not a 6th gen expert, but I do know these things... Most would recommend doing timing chain tensioners, pcv oil catch can, and doing a valve body upgrade so the tranny lasts.
Yo thanks, I fa sure don't wanna have to replace it again!! Should I pull tha engine from top or drop from bottom?
Old Nov 11, 2014 | 07:45 AM
tosheto's Avatar
You can do either, depending on what tools you have. I planned to do mine from the bottom, but eventually ended up doing it from the top.
Old Nov 11, 2014 | 11:34 AM
po8pimp's Avatar
change out your intake gaskets with these: http://www.nwpengineering.com/Phenol...rs.html#VQ35DE
change out your oil pump to one of these: http://www.z1auto.com/prodmore.asp?m...50z&prodid=920 or http://www.injectedperformance.com/n...for350zg35.htm
Also change these out:
Knock sensor
Spark plugs to NGK iridium plugs
Timing chain tensioners
Transmission mounts
Engine mounts (Recommend getting these as well: http://racinglineperformance.com/sho...p?IDProduct=19
These are the main things I would change out. There are many different performance mods you can do, that is another ball game though.
Old Nov 12, 2014 | 11:19 AM
97
Knock sensor
Transmission mounts
i got a 97 maxima also that im gunna "do up". I honestly think ima sell my Acurs Rsx Type-S and put all of wat i get out of it and build the hell out of the 97. only drawback is that ima have to do a manual trans swap. Ive never swapped an auto to a manual....i can only imagine how much of a damn job that is.
Old Nov 12, 2014 | 12:46 PM
Gotsmanlai's Avatar
All good recommndations^
I'd also add a transmission cooler if you have the funds, to further prolong the life of fragile transmission our 6th gens have.
smplyamzng
Dec 13, 2015 01:19 PM
Chef N
Sep 22, 2015 11:20 PM
TonyJr
Aug 20, 2015 12:14 AM
Tommy6905
Aug 14, 2015 11:54 AM
Samedi
Aug 13, 2015 04:05 PM
